can i still get cert/warrent if i solid mount engine and box
Postby drift-monkey » Thu May 20, 2010 9:27 pm
just wondering if they will cert or warrent a car which engine ect is solid mounted? cheers
drift-monkey
Postby Bling » Thu May 20, 2010 9:41 pm
What did the certifier you plan to use say?
:wink:
Postby d1 mule » Thu May 20, 2010 10:10 pm
you can but both engine and box have to be solid mounter/ rubber mounted. no mix and match
d1 mule
Postby matt dunn » Thu May 20, 2010 10:12 pm
why on earth are you solid mounting it anyway?
all it will do is break stuff, trust me we've tried it.
Postby drift-monkey » Fri May 21, 2010 9:37 am
eaiser option, its going into a s13 so everything is real close, clutch master ect, talked to a few ppl and they have solid mounted theirs and no prob, im just wondering if i can get a cert with it though. Cheers
drift-monkey
Postby Adoom » Fri May 21, 2010 6:58 pm
drift-monkey wrote:eaiser option, its going into a s13 so everything is real close, clutch master ect, talked to a few ppl and they have solid mounted theirs and no prob, im just wondering if i can get a cert with it though. Cheers
If you think it will hit stuff, just get real stiff urethane mounts, and a brace to stop it rocking.
I just have ordinary urethane mounts and my engine doesn't budge.
Like Matt says, you will eventually break stuff if its solid mounted. And rubber or urethane mounts mean the alignment can be off a little and it will be fine. With solid mounts, brackets, etc everything will have to be spot on, or you get stresses and again, shit will break.
Solid mounts are for racing cars that get rebuilt often.
Adoom
