silvertop VVT solenoid, o-ring
Postby Leon » Thu Sep 23, 2010 11:17 am
Anyone know the specs for this, and where to source it?
I emailed Toyota and the only way to get the o-ring is to spring $190 for a whole new solenoid.
I tried a "this looks close" o-ring yesterday but it was slightly too fat, so the solenoid wouldn't go back in.
Postby Flannelman » Thu Sep 23, 2010 11:51 am
Try a gasket shop and match it to one off the shelf. Did this for the o-ring between the block and oil filter housing. Toyota $21 V gasket shop $2.
Could also try plumbers outlets, milking machine repair, even supercheap. Just say its dealing with heat and oil.
Oh, and use some lube when putting anything rubber into a tight space. Makes the job alot easyer.
Flannelman
formerly known as Affroman
Postby CAMB01 » Thu Sep 23, 2010 11:52 am
Mana Bearings in Porirua if you go in with the oring, they can match it up.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Thu Sep 23, 2010 12:06 pm
What you can do is get a smaller o-ring and stretch it over, thats how I did mine.
Postby neo » Thu Sep 23, 2010 1:09 pm
schdorerco ? or what ever they are called these days have a supply of O rings if you haven't tried there already.
neo
Postby Leon » Thu Sep 23, 2010 3:09 pm
Yeah, they've changed name ... I went in there a couple of years back, and I've never met anyone as grumpy and unhelpful as the fellow I encountered that day. Never been back since 8)
Postby Dell'Orto » Thu Sep 23, 2010 9:05 pm
Schrodoco, and yeah they can be quite unhelpful.
Postby Leon » Thu Sep 23, 2010 9:49 pm
nah, they were previously called Schrodoco, they're called something else now.
Postby Dell'Orto » Thu Sep 23, 2010 9:53 pm
When I rang the week before they were still Schrodoco?
Postby CAMB01 » Thu Sep 23, 2010 10:42 pm
There called Bearing, Tool & Industrial Supplies now.
They have moved from Tory street to Abel-Smith street.
Have been going to get bolts etc for my car, very helpful and friendly, but im not a Joe Blogs to them.
CAMB01
Postby MrOizo » Thu Sep 23, 2010 10:49 pm
These guys would have something! Re-sealed my PS pump a few years ago for about $3, compared to the kit from toyota which was ~$100?
http://sealhouse.co.nz/
Bit far to go though :/
MrOizo
Toyspeed Legend
Postby matt dunn » Thu Sep 23, 2010 11:19 pm
I got one from a diesil pump repair shop for mine.
The one here has a whole room of different sized o-rings on the wall and in racks.
Postby Leon » Fri Sep 24, 2010 9:35 am
CAMB01 wrote:Mana Bearings in Porirua if you go in with the oring, they can match it up.
This is what I shall be doing.
I also have another used VVT solenoid to try as well in the interum. 8)
Many thanks for your various advices in the thread. Much appreciated.
Postby Bazda » Thu Dec 02, 2010 2:16 pm
I just found out the O-ring inside the solenoid works for the outside as well :). Its slightly different but works.
Postby Leon » Thu Dec 02, 2010 4:54 pm
I drove my car at speed into a bank at a motorsport event, thus o-ring priority has diminished ;)
Also it would seem that it was a cam seal leak the whole time. Sigh.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
