Nickel alloy vs recommended platinum spark plugs
Postby 2win2rbo » Sat Oct 09, 2010 4:32 pm
I just found out that after 10s of thousands of ks that I was running nickel alloy NGK spark plugs (BKR6E-11) on my 5SFE. According to the service manual, the minimum recommended spark plug type is platinum (BKR6EP-11 or equivalent). Even auto parts stores told me I should be running the platinum ones (as a minimum). What are the consequences of running the lower grade nickel alloy BKR6E-11s if the recommended ones are platinums?
1993 トヨタ クレスタ TOURER S JZX90
2win2rbo
Postby Al » Sat Oct 09, 2010 5:23 pm
The only consequence is that you will probably only get 30-40,000kms instead of 100,000, but pay 1/4 of the price.
Nothing wrong with cheap NGK coppers, too many pointy shoe salesmen try and get you to spend big bucks of plugs which you don't need.
Al
Postby MAGN1T » Sat Oct 09, 2010 6:41 pm
Second hand platinums from pick a part.....platinums will outlast the motor.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Dell'Orto » Sat Oct 09, 2010 9:15 pm
Wouldnt bother with platinum. Copper works perfectly well...there may be a minor gain with iridium plugs, but cost vs benefit, its entirely not worthwhile.
Postby MR2BOY23 » Sat Oct 09, 2010 9:36 pm
for a 1/4 of the price, I'd just go with the NGK coppers and the change them on a more regular interval. For turbo application you'll probably find your changing them more often
For a car where it's more difficult to change the spark plugs, like a Subaru I'd go with platinums
MR2BOY23
Postby 2win2rbo » Sat Oct 09, 2010 9:53 pm
Has anyone tried Autolite plugs? What are your insights toward them?
2win2rbo
