st185 Front center engine mount
Postby GT4-Addict » Wed Oct 20, 2010 6:05 pm
My front center engine mount is FARRRRKKKEEEDDDD, put politley. I tried to track one down through autolign and BnT, but there isnt one avaliable in the country through them, I was wondering if the engine mounts of any old st18x celica will do the trick?
Any info would be really great!
GT4-Addict
Postby levinguy » Wed Oct 20, 2010 6:21 pm
tried toyota?
levinguy
Postby touge_ae101 » Wed Oct 20, 2010 6:29 pm
not sure who BnT get their mounts through but i would say your best bet would be to try stocks. partsmaster also carries stocks' range.
surely you should be able to find something alot of them are interchagable.
touge_ae101
Postby GT4-Addict » Wed Oct 20, 2010 6:35 pm
Im trying not to go TGP, its already 117 for an aftermarket mount, and i think TGP will just be more expensive.
Ahhhhh the joys of an apprentices wage!
I dont think we have Partmaster/Stocks down here unfortunatly.
I also plan on going round some of the wreckers in my lunch break tomorrow, I was hoping to have it in by labour weekend but i dont think it will be a happening thing!
GT4-Addict
Postby Skin » Wed Oct 20, 2010 6:44 pm
GT4-Addict wrote:Im trying not to go TGP, its already 117 for an aftermarket mount, and i think TGP will just be more expensive.
Um, have you actually tried? I might be used to australia pricing now, but im pretty sure engine mounts were line priced? and im sure they are a hell of a lot cheaper than $117....
Too often people just ASSUME genuine will be more expensive, and quite often they arent!!!
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby RobertC » Wed Oct 20, 2010 6:48 pm
Still might be worth trying 1I1 (Mark) from toyota. Details are in the sponsors section just flick him an email. I had to replace a AE111 front engine mount not long ago was only ~$80.
RobertC
Postby GT4-Addict » Wed Oct 20, 2010 6:56 pm
Ill give mark a PM then, maybe he can sort me out with a genuine one, and ill track down a second hand one tomorrow for the mean time. Id still like to know if any other st18x or any other vehicle for that matter will work if anyone knows?
GT4-Addict
Postby loudstealthGT-Four » Wed Oct 20, 2010 8:08 pm
GT4-Addict wrote:Ill give mark a PM then, maybe he can sort me out with a genuine one, and ill track down a second hand one tomorrow for the mean time. Id still like to know if any other st18x or any other vehicle for that matter will work if anyone knows?
Im pretty sure the other st18x models are the same. Dont see why they would use a different mount on the same car
loudstealthGT-Four
Postby Malcolm » Wed Oct 20, 2010 8:23 pm
Well the others have a different gearbox, so it's possible the mounts could be different, but I suspect the rubber part will be the same with a different bracket going from there to the gearbox
Postby DeeCee » Wed Oct 20, 2010 8:24 pm
part numbers:
st185 mount = 12361-74150
st182/3 mount = 12361-74130
there are no matching entries in the EPC for the st185 mount, but the bracket that holes the mount is generic for st18x
of note, I have change my st185 side mounts to st182 gen2 mounts as they had more urethane in them.
Didn't really look at the front or rear mounts as I'm changing to polyurethane inserts.
Mount from Pick a Part is around $12. Will take a bit to get it off, but you have to drop the lower cross member by removing the grommets to access the bolts that attach the mount and the bolts that attach the x-member to the chassis. Note, some pipes are mounted to the cross member, so watch what you cut, espec AC piping.
Also, old mount will be worn, so not sure how much life you will get out of it. I got my poly inserts from http://www.speed-source.net/ Shiipping was around 10 days from the states.
Hope this helps
GT Four Adovansu
DeeCee
Postby DeeCee » Wed Oct 20, 2010 8:25 pm
gah - not thinking clearly.. too tired :( soz M
GT Four Adovansu
DeeCee
Postby loudstealthGT-Four » Wed Oct 20, 2010 8:27 pm
only the rear of the gearbox is different, the front is the same
loudstealthGT-Four
Postby GT4-Addict » Wed Oct 20, 2010 8:39 pm
Hmmm, it may be possible to use st18x mounts then i gather? my mount has completley collapsed, so even if i fire one in temporarily and it 'Does the Job" for the mean time, itd be acceptable to me
GT4-Addict
Postby DeeCee » Wed Oct 20, 2010 8:42 pm
why not call some local wreckers and try it? unless wreckers are changing a bit for one.
GT Four Adovansu
DeeCee
Postby loudstealthGT-Four » Wed Oct 20, 2010 8:45 pm
i might have one in the garage at my parents place, can check tommorow and can drop it off to you on my way through dunners tommorow afternoon/night
just pm me your cell phone number and ill let you know how i get on
loudstealthGT-Four
Postby GT4-Addict » Wed Oct 20, 2010 9:03 pm
Just sent you a PM loudstealth, and yea i will call around the wreckers tomorrow at lunchtime, im sure i will manage to get something workable somewhere!
GT4-Addict
Postby XS1V » Thu Oct 21, 2010 9:37 am
If loud stealth doesnt have one, im sure i have a number of them :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby GT4-Addict » Thu Oct 21, 2010 7:16 pm
Hey brad, How much would you want for one? the mount that loudstealth had was a rear mount unfortunatly
GT4-Addict
Postby XS1V » Thu Oct 28, 2010 1:49 pm
$10 :)
Brad
XS1V
Postby AE92-5ONIC » Thu Oct 28, 2010 2:26 pm
Mount Shop would have them, don't know if they have a shop in Dunedin, but there's one in ChCh, but they are by far the cheapest on engine mount distributors.
That's if XS1V doesn't come sell you one.
AE92-5ONIC
