Car Overheating
Car Overheating
Postby spoonza6 » Mon Oct 25, 2010 8:19 pm
got this annoying problem im trying to fix. About 3 weeks ago the starlet started overheating so i checked the radiator and it wasnt leaking so decided to chane the thermostat as it looked pretty old. That didnt work but when i run no thermostat i can drive for quite sometime before the temp starts to creep up.
Today i decided to change the waterpump, old one didnt look like it was too bad aand prob changed about 50,000km ago but i changed it anyway since i had already removed the old one. Unfortunately still no luck and car overheats. all the sensors are plugged in and im stumped. i left it running for about 20min and it idled fine and sat at normal temp but i went for a quick boost down the road and back and in that short distance the overflow bottle started boiling all the water out.
What else can i look at checking cause im lost. Fan is working fine to.
car is a ep82 gt starlet
spoonza6
Postby levinguy » Mon Oct 25, 2010 8:46 pm
blocked radiator?
inbeforethemagn1tbhg
levinguy
Postby spoonza6 » Mon Oct 25, 2010 8:48 pm
how do i check if the radiator is blocked?
spoonza6
Postby descent » Mon Oct 25, 2010 9:04 pm
spoonza6 wrote:how do i check if the radiator is blocked?
pulling it out and taking it to a shop. get it rodded/flushed
you can run a hose in it and see how much comes out the bottom, but that only tells you that you have some flow.
descent
Postby blindnz » Mon Oct 25, 2010 10:40 pm
Id go with a radiator problem. i had pretty much the same issue in my old trueno, picked up a cheap 2nd hand radiator fixed it up straight away.
blindnz
Postby allencr » Tue Oct 26, 2010 5:29 pm
Look in it, the dozen or so tubes that are visible through the cap should be open with only a bit of mineral buildup. If more then 2-3 out of the dozen look clogged it has to betaken apart & cleaned.
Rev it when the thermo is open & no cap, and if it over flows instead of being drawn down & into the engine, then its clogged.
allencr
Postby deaf_rattle » Tue Oct 26, 2010 7:35 pm
agreed
Postby pc » Tue Oct 26, 2010 10:44 pm
Take it out and lie it on a flat surface with the cap on and the hose feeds pointing up. pour a jug of near boiling water into it till it is full.
Put your hand all over the radiator to see if it is hot everywhere... if not, that area is blocked.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
