The motor is the 1500cc 5E-FTE (turbo, 220Kw) in my race car , is 5-6 litres about right , too much or not enough ?
Thanks for your replys
DexGT wrote:I have a fully baffled / trap door'ed sump with a pick up set at 8mm from the bottom and a run big end/s.
So at the moment I'm looking at options and if I dry sump the motor I want to put the tank in the engine bay , therefore trying to figure out how big a tank I need .
I may just have to get a better oil supply to the big ends, the investigation continues
Thanks for the reply's
matt dunn wrote:There is no reason a well made wet sump wont work.
iOnic wrote:I'd focus my attention on figuring out exactly what killed the bearings and then go from there.
iOnic wrote:I'd focus my attention on figuring out exactly what killed the bearings and then go from there. What does your oil pressure gauge say during cornering?
Also have you considered an Accusump unit? They're a lot cheaper than a full dry sump system but could give you that extra boost of pressure if/when you need it.
