fuel float not floating
Postby hsmidy » Fri Nov 12, 2010 10:42 am
Hey guys
so i was driving home and next thing my fuel gauge just starts dropping reallly fast all the way down to E and stayed there, turns out my fuel float has decided to stop floating.
short of replacing the sender unit, I've thought of just replacing the float but is there any other cheap easy ways?
hsmidy
Postby evil_si » Fri Nov 12, 2010 11:26 am
could always try filling the float with expanding foam,
try and find a fuel resistant foam
evil_si
Postby rollaholic » Fri Nov 12, 2010 12:36 pm
bit of cork?
does cork float in petrol?
Postby hsmidy » Fri Nov 12, 2010 2:30 pm
yeah im just trying to find something that wont like break down in petrol.
all options considered....im a tight ass dont really want to buy a new sender
hsmidy
Postby Bling » Fri Nov 12, 2010 3:17 pm
Use the trip meter so you know when its about empty :wink:
Cost: $Free
Postby 1I1 » Fri Nov 12, 2010 3:23 pm
BZG|Bling wrote:Use the trip meter so you know when its about empty :wink:
Cost: $Free
Just be sure to have a can of fuel handy if trying to work this out if you don't know how far you can go on one tank! :lol:
TRD Clicky >>Here
1I1
Postby hsmidy » Fri Nov 12, 2010 3:31 pm
Cost: $Free
lol nice, that might have to do till i get a solution, im guessing that the float has a hole in it, short of trying plastic welding does any one know of a glue (loctite etc) that doesnt break down in petrol?
hsmidy
Postby sergei » Fri Nov 12, 2010 4:25 pm
You could try hot glue gun. Or just soldering iron and "weld" the hole.
Postby .:O4AGTZ:. » Fri Nov 12, 2010 4:52 pm
Put a duckling in it, u get to know how much gas you have and the duckling gets to swim...its a win win situation...u will know when you are low on gas as it will be able to walk around in the dregs at the bottom
.:O4AGTZ:.
Postby tsoob » Fri Nov 12, 2010 6:15 pm
go to pick a part and 'borrow' a float
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby iOnic » Fri Nov 12, 2010 6:16 pm
Just go to pickapart and rob a float out of something else and make it fit
