How to unlock boot!
How to unlock boot!
Postby .:O4AGTZ:. » Tue Nov 16, 2010 12:07 pm
Well my partner seems to constantly break things on her car (ST170/ST171 corona). Now the boot will not open, with the latch or with the key. When you put the key in it doesnt turn and when you pull the lever near the drivers seat it just pulls and you dont get that feel when it pops.
For some reason the back seats dont come down, so I think I will actually have to take it out to have a look. Is it possible to easily open a boot from the inside? I suspect it is not an issue with the cable, but the lock itself.
Any advise appreciated!
.:O4AGTZ:.
Postby tsoob » Tue Nov 16, 2010 12:59 pm
take the seat out and see if you can get to the latch.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby BZG Wagon » Tue Nov 16, 2010 1:10 pm
Agree - sounds like unbolting the seat is the best approach (presumably something is wrong with the latch?).
Shouldn't be too hard to get to.
BZG Wagon
Postby .:O4AGTZ:. » Tue Nov 16, 2010 1:41 pm
Yeah thats what I will be doing, im just lazy.
Definately something wrong with the latch though
.:O4AGTZ:.
Postby Bazda » Tue Nov 16, 2010 2:26 pm
Yep you will have to get the seat down. All you need is a flat head screw driver to flick the lever in the latch.
Postby .:O4AGTZ:. » Tue Nov 16, 2010 5:52 pm
Bazda wrote:Yep you will have to get the seat down. All you need is a flat head screw driver to flick the lever in the latch.
Ah sweet, never even looked at it so wasnt aware what I would be able to get to if anything. Will give it a go this weekend and see what happens
.:O4AGTZ:.
Postby deaf_rattle » Tue Nov 16, 2010 6:14 pm
sst#10064
Postby .:O4AGTZ:. » Tue Nov 16, 2010 6:57 pm
deaf_rattle wrote:sst#10064
I would preferably like it to be able to close afterwards as well...
.:O4AGTZ:.
Postby B1NZ » Tue Nov 16, 2010 6:59 pm
have you tried putting a bit of pressure on it while either turning the key in the lock or getting someone to pull the lever?
Maybe give it a wiggle either way might work if it has pressure on it somehow?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby no_8wire » Tue Nov 16, 2010 7:00 pm
:lol:
no_8wire
Postby h8wrxs » Tue Nov 16, 2010 8:50 pm
hahaha i was going to suggest a crowbar when i first read this but i thought i shouldnt be a smartass lol
h8wrxs
Postby RomanV » Tue Nov 16, 2010 9:06 pm
B1NZ wrote:have you tried putting a bit of pressure on it
Fixed for childishness.
Postby darkwolf » Tue Nov 16, 2010 9:24 pm
Just check that the lever below the lock inside the boot hasn't been moved... I own a ST171 2.0 GL. Moving house, took off sharpish, microwave hit lock. Thought I'd stuffed it because it wouldn't undo. Took plastic cover off and found a lever, moved it, everything started working again.
Of course, you have to get in the boot first.
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby deaf_rattle » Wed Nov 17, 2010 2:46 pm
:lol:
lol, make sure you have a hammer ready to hit the hookers with when they make a run for it though.
Postby .:O4AGTZ:. » Wed Nov 17, 2010 5:39 pm
Its okay, they're tagged
.:O4AGTZ:.
