Starting issue
Starting issue
Postby WAY TC » Tue Nov 16, 2010 4:59 pm
4efe:
When I start my car my engine stutters after it fires, stutters for a few seconds.. then runs fine. has been deteriorating over last few weeks.
The reason im asking is because it ONLY happens at middle of the day.
(12noon peak temps)
but the engine is cold as its been sitting since 8am.
starts fine when its cold in the morning, or when i have been using it all day and it starts first pop.
so weird. any ideas?
WAY TC
Postby GTTpower » Tue Nov 16, 2010 5:19 pm
Cold start injector playing up?
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby blindnz » Tue Nov 16, 2010 5:47 pm
coolant temp sensor? although it should be throwing some codes and running rich.
blindnz
Postby Akane » Tue Nov 16, 2010 6:36 pm
FYI peak temp of a day is after midday (early afternoon), not 12pm.
Postby Bling » Tue Nov 16, 2010 6:47 pm
FYI I was sweating in the sun long before 12pm today :lol:
Postby Quirky » Tue Nov 16, 2010 6:52 pm
My car use to do this. Early morning starts, its fine.
However hot starts weren't good.
The car was running too rich, which is ok for a cold start. Around 70ms on 440cc injectors, and the hot start was 60ms which was way too much.
Eventually trimmed it down to 20-30ms and it cranks straight away.
On a standard car I would guess its possibly the coolant sensor, its the only sensor on the car that monitors engine running temperatures.
Hello There
Quirky
Postby Akane » Tue Nov 16, 2010 7:22 pm
BZG|Bling wrote:FYI I was sweating in the sun long before 12pm today :lol:
FYI my car has no aircon so I feel your pain :cry:
Postby touge_ae101 » Tue Nov 16, 2010 7:29 pm
do you live in your car? :lol:
touge_ae101
Postby Akane » Tue Nov 16, 2010 7:43 pm
no, but I made a trip today to a job interview 2pm with a broken window regulator on the driver's side window. so epic sucks to be me.
Postby allencr » Wed Nov 17, 2010 1:51 pm
Try it with the throttle pushed down, but don't let it rev whenit does start. Some that are running rich or leaking injectors need a little more air for a hot startup.
allencr
Postby gepsk8 » Thu Nov 18, 2010 8:25 am
have Check/charged basic's? Spark Plugs? Airfilter?
how many k's? is cap rotor or lead stuffed?
Fuel Filter
O272754663
gepsk8
Postby Tagged » Sat Nov 20, 2010 2:11 am
lol i had a ride in a friends car for around 20 min on open road, found out there was no aircon and the option was get my face torn off by the wind or get baked.....dang....
Tagged
