Hand brake light
Hand brake light
Postby Stott69 » Thu Nov 18, 2010 9:54 pm
Looking at a '92 Aristo. Great looking car and all but its got a fault with the hand brake dash light, some times it stays on. What could it be and how hard to fix?
Image jzs147 Aristo money pit
Stott69
Postby samlloyd » Thu Nov 18, 2010 10:00 pm
Top up brake fluid resovoir
samlloyd
Postby RS13 » Thu Nov 18, 2010 10:00 pm
Probably a stupid question, but have you checked the brake fluid level?
RS13
Postby Stott69 » Fri Nov 19, 2010 6:03 am
Guy recons its not the fluid level
Stott69
Postby Looonie » Fri Nov 19, 2010 7:33 am
The brake warning light on the dash is triggered by either low brake fluid level (can come on when cornering, accelerating, braking if the fluid level is borderline) or the handbrake position sensor itself.
If its intermittant then my vote would be fluid level (but thats piece of piss to check when you look over the car). If not, the sensor shouldn't be too hard to track down and check its bolted securely and has not wear and tear on the wire.
99% of instances where the light comes on at random though is brake fluid level. If by some fluke the fault with this car is the other 1%, I don't imagine it would cost too much to fix (at most either adjustment of the handbrake (foot brake in these yes?) or new sensor from wreckers).
Rumple dee pumple dee doo...
Looonie
Postby rollaholic » Fri Nov 19, 2010 7:50 am
the fluid sensor could be faulty also.
but its a toyota, chances are its on because someone has been $&#$% with it
Postby the fallen303 » Fri Nov 19, 2010 9:23 am
does it keep making a humming noise? if it's a turbo aristo, they have a nitrogen brake booster, instead of a vacumn one, and they're prone to shitting themselves and running out of gas. i'm not sure if when they get low wether they also trigger the handbrake light. look around on jzs147.com.au for info.
true house of JZ
Stay true to the origin
the fallen303
Re: Hand brake light
Postby 2win2rbo » Fri Nov 19, 2010 4:11 pm
Stott69 wrote:Looking at a '92 Aristo. Great looking car and all but its got a fault with the hand brake dash light, some times it stays on. What could it be and how hard to fix?
I think he's talking about the "hand brake dash light." If that is the case, it could be because of a faulty sensor usually located under the handbrake lever. It's not too difficult to do.
1993 トヨタ クレスタ TOURER S JZX90
2win2rbo
