Bleeding Brakes - ABS
Postby Jebus » Tue Nov 23, 2010 10:12 am
Whats the procedure for bleeding brakes with ABS?
My 97 Qualis brake pedal goes to the floor pretty easily. I bled each wheel the normal way and when the cars off the pedal is hard as rocks, soon as the engines running its soft and goes to the floor?
any help?
Jebus
Postby B_giB » Tue Nov 23, 2010 10:47 am
Had same thing with my old levin, turned out brake pads where rather worn
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Girvs » Tue Nov 23, 2010 11:33 am
Are you bleeding with the engine running? If so, don't.
Just bleed normally while the engine is off. I did have a quick google and the only thing I did noticed was this
Extract on ABS below from. http://www.popularmechanics.com/cars/ho ... ce/4213448
The good news: Air that has entered the ABS controller can be bled out. Bad news: Some vehicles require the use of a hideously expensive proprietary ABS scan tool to cycle the pump and valves to purge the last of the air. But there's a simple solution to that: Never let any air enter the system. You can flush a system with fresh fluid by using nothing more than a wrench that fits the bleeder bolts -- and a helper with a normal attention span.
Update: This link has a few pages which may interest you. Can't be assed reading it all, but theres about 9 or so pages on it
http://autorepair.about.com/od/troubles ... brakes.htm
Girvs
Postby Jebus » Tue Nov 23, 2010 12:39 pm
Im bleeding it with the car off, and it feels really good and pedal is stiff. soon as the car is running all the feeling is gone and with a descent push on the pedal it touches the ground
cheers, ill have a read through soon!
Jebus
Postby h8wrxs » Tue Nov 23, 2010 4:39 pm
might be a silly comment but is there plenty of brake fluid in the resevoir?
h8wrxs
Postby Girvs » Tue Nov 23, 2010 5:10 pm
Another really silly question is your mate taking his foot off the brake and sucking some air back into the line rather than leaving it depressed when you retighten the nut?
Girvs
Postby rollaholic » Tue Nov 23, 2010 7:18 pm
what did ya do to warrant the bleeding?
Postby holden_fan2005 » Tue Nov 23, 2010 7:57 pm
Try it with the key on (not started).
After, turn the car on, pump the brakes up to build pressure then hold. Does the pedal slowly go to the floor?
holden_fan2005
Postby matt dunn » Tue Nov 23, 2010 9:51 pm
Pump the pedal a few times with the car turned off and make sure it is nice and hard and feels ok.
Keep the pedal pushed and start the car and dont let it off.
Does it sink all the way to the floor when the car starts?
If so it's the booster working.
have struck it on a honda, and it's normal.
You will find that how hard you are pushing the pedal to get it to the floor,
is way past the pressure that it will lock up the wheels and the ABS pushes the pedal back.
If you are confident, drive it and try the brakes on the road then decide if there is a fault.
Postby Jebus » Wed Nov 24, 2010 8:25 am
Girvs wrote:Another really silly question is your mate taking his foot off the brake and sucking some air back into the line rather than leaving it depressed when you retighten the nut?
No air is getting back, ive bled brakes a billion times on other cars, just never with ABS. Thanks though
matt dunn wrote:Pump the pedal a few times with the car turned off and make sure it is nice and hard and feels ok.
The brakes seem to be working ok, I have been driving it like this for quite a while, theyre not 100% but I dont thin ktheyre dangerous,
Reason why im doing this is because I failed a WOF on 'brake pedal going to the floor'
Jebus
Postby matt dunn » Wed Nov 24, 2010 8:30 pm
Jebus wrote:Reason why im doing this is because I failed a WOF on 'brake pedal going to the floor'
Some WOF guys wouldn't have a clue. Not a VINZ or VTNZ was it?
Anyone that does warrants but doesn't do repairs usually have no clue on how stuff works as over time they loose there brain in a place like that.
Postby rollaholic » Wed Nov 24, 2010 9:34 pm
matt dunn wrote:Anyone that does warrants but doesn't do repairs usually have no clue on how stuff works as over time they loose there brain in a place like that.
qft
Postby CAMB01 » Wed Nov 24, 2010 10:12 pm
Had the exact same problem with my EVO with ABS when i was getting it back together.
Bled the brakes normally with the key on, and the pedal felt good and hard.
Started the car and the pedal would go to the floor.
I bled the brakes quite a few times with the same result.
Then decided to bleed them with the engine running and it was perfect, hard pedal with or without engine running.
Im assuming with the engine running the valves were open in the ABS pump to remove the air.
There are no bleed valves on the pump either.
Just my 2c of experience.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Jebus » Thu Nov 25, 2010 8:56 am
Ah sweet, ill try that.
Thanks guys
Jebus
