ae101 rear brake balance
Postby krock » Mon Nov 29, 2010 10:43 pm
hi, my car (ae101 fxgt) has a large imbalance between rear brakes, mechanic has suggested that it is probably the brake proportioning valve as these fail fairly regularly on toyotas, or maybe it was corollas in particular.
From what i gathered the disks, calipers and pads were ok as he didn't find any problems with them other than a bolt which was missing on a caliper and he replaced for me.
can anyone back this up? a) that this could be likely cause of imbalance, and/or b) that this is a common problem...
Cheers for any help
krock
Postby Lloyd » Mon Nov 29, 2010 10:52 pm
Yes and yes. You don't trust your mechanic?
Postby Bling » Mon Nov 29, 2010 11:10 pm
Yes and Yes.
Postby strx7 » Tue Nov 30, 2010 6:51 am
there was a thread about these 7-10 days ago
Postby krock » Tue Nov 30, 2010 5:47 pm
thanks for the help
krock
Postby rollaholic » Tue Nov 30, 2010 6:49 pm
send valve to yems for rebuild, way cheaper!
Postby krock » Tue Nov 30, 2010 7:24 pm
ok, i'll ask him . cheers :D
krock
Postby allencr » Tue Nov 30, 2010 8:39 pm
Is there actually valve between the LR and RR brakes or just a T?
If it doesn't have a problem between the F & R where the valve is plumbed in, then it isn't a valve problem!
[quote=Matt Dunn]Almost all FWD cars are split diagonal braking systems, [/quote]
Thanks, news to me, except for what Volvo's been doing for 40 years.[/b]
allencr
Postby matt dunn » Tue Nov 30, 2010 10:32 pm
allencr wrote:Is there actually valve between the LR and RR brakes or just a T?
so the LR and RR are not connected at all, there is not a "T" as you say,
and from my understanding they kinda have two valves, one for each rear wheel, so one can jam and you get too much brakes on one rear wheel, although both thye valves are built into one unit.
Postby Bling » Tue Nov 30, 2010 10:48 pm
Do cars with ABS use the same valves?
eg ae111 abs
ae111 non abs?
Postby matt dunn » Tue Nov 30, 2010 10:56 pm
BZG|Bling wrote:Do cars with ABS use the same valves?
eg ae111 abs
ae111 non abs?
I would presume so as you still need the same bias with abs,
otherwise the abs would kick in to stop locking the rears everytime you braked.
Postby TRD Man » Tue Nov 30, 2010 11:24 pm
Old Toyota brake hoses (about the age of AE101) have been known to collapse internally causing a blockage which will effect the balance.
It is far easier, and less costly, to check this before the proportioning valve.
TRD Man
Postby rollaholic » Wed Dec 01, 2010 7:44 am
there are also two types of P valves, one with an alloy hosing and i believe 5 inlet/outlets and one with a cast housing and only 4
or something like that
Postby krock » Wed Dec 01, 2010 6:37 pm
TRD Man wrote:Old Toyota brake hoses (about the age of AE101) have been known to collapse internally causing a blockage which will effect the balance.
apparently i have a "cracked" rear brake hose, i havent checked it out yet, and im not sure if it could be cracked and not be leaking, but maybe that could be connected with my imbalance and not the prop valve...
krock
Postby rollaholic » Wed Dec 01, 2010 7:55 pm
the outer sheath can be cracked or perished from age / heat etc with the inner section retaining its integrity, for now at least.
Postby krock » Wed Dec 01, 2010 8:23 pm
yeah ok. so could be either/or then. have to try one first then.
krock
Users browsing this forum: No registered users and 33 guests
