Rick wrote:I have got a Runx and found it quite peppy down low.
Have you changed the thermostat?
sergei wrote:sidewz wrote:sergei wrote:What might help is cleaning the MAF.
Yeah, that sounds like a good place to start, thanks Sergei.
Seems to be a common cause of issues.
Do it with crc carb cleaner, it is great for that.
levinguy wrote:sergei wrote:sidewz wrote:sergei wrote:What might help is cleaning the MAF.
but its injected?
sergei wrote:levinguy wrote:sergei wrote:sidewz wrote:sergei wrote:What might help is cleaning the MAF.
but its injected?
But it is a solvent?
TRDWGN wrote:I think you will find the ECU retards the ignition a bit until the engine warms up, the blacktops do a similar thing
levinguy wrote:sergei wrote:levinguy wrote:sergei wrote:sidewz wrote:sergei wrote:What might help is cleaning the MAF.
but its injected?
Uploaded with ImageShack.us
Quirky wrote:What is your idle from cold start?
And your idle when warm?
Should be 2000rpm cold, as you say, which drops to 1300rpm until the car warms up then drops again to around 800rpm.
sidewz wrote:Quirky wrote:What is your idle from cold start?
Thats what it used to do.
Warm idle is about 800 or so, but it sometimes feels a bit too low. Maybe a bit rough.
Not sure about cold. I will ask the mrs to check in the morning, but I wouldnt hold my breath on a useful answer.
"Uhm, it started?? What more did you want?"
But it doesnt seem to kick up to 2k any more on first start.
Maybe i should reset the ecu again...
