W58 to AE85...
W58 to AE85...
Postby stalker » Fri Dec 10, 2010 11:37 pm
Tried searching, but my male vision got the better of me! (Ie. I got board after 10min of reading) :lol:
What I want to know is:
When putting in my W58 into my AE85, what crossmember can I use??
Will a W58 one work if I just re-drill the holes to match up with the AE mounting points? Or is there some pain in the a$$, complicated thing I have to do to make it work?
Cheers all
8)
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby d1 mule » Fri Dec 10, 2010 11:50 pm
yes it will, from memory just slot the 2 front holes and it works. only has 2 bolts tho but its all good
d1 mule
Postby evil_si » Sat Dec 11, 2010 8:06 am
cert man will most probably require more than just 2 holes,
think the last one i did i cut the feet of the mount off, bolted them to the chassis and modified the rest of the mount to suit
evil_si
Postby d1 mule » Sat Dec 11, 2010 6:44 pm
had a look, the x member holes off the W55/7/8 dont line up, i just driled new holes.
factory has 2 bolt mounts why should it be any different??
d1 mule
Postby AE85.6 » Mon Dec 20, 2010 7:30 pm
Read somewhere (maybe here or GD ?) ae85 auto ones work but still need the holes slotted slightly, the guy used his for cert but I think from memory it was using washers over the holes.
I hoarded one to try the same when I thought about putting w series in my levin, thought maybe weld the washers in place though ? Don't actually know how close a fit was as never had it dummied up.
Would let you have it to test if of interest however listed a whole lotta crap on trademe and someone has hit reserve, if is of interest its only up to $15 though....
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby stalker » Mon Dec 20, 2010 9:03 pm
Ahh true...might has to rungi something up :lol:
Ill go put a bid in and see if I can win me your one and least give it a shot.
stalker
Postby AE85.6 » Mon Dec 20, 2010 9:33 pm
Ye if I had seen your post earlier I would have offered before listing it,
only recently been having a nosey on here again just been slack for a long time heh.
AE85.6
Postby stalker » Mon Dec 20, 2010 9:58 pm
hehe tis all good.
stalker
