evil_si wrote:No need to run in a turbo, just drive it how you want to from the start
things to make sure of when installing a turbo are
Prelude turbo with fresh oil before starting
On cranking and first start hold the compressor wheel so it won't spin to allow plenty of oil to lubricate it before allowing it to spin
h8wrxs wrote:evil_si wrote:No need to run in a turbo, just drive it how you want to from the start
how exactly do you hold the compressor wheel when cranking?
evil_si wrote:Yes cranking / starting, but just let it idle if it starts,
hold the compressor wheel or the nut with your fingers,
just get a good grip on it before someone cranks it for you,
Don't jam any thing metal in it to try and hold it as you will more than likely damage it,
Might sound daunting but it is actually very safe
h8wrxs wrote:no worries, will give it a go this week when i bolt up my new toy :d
will let you know how many fingers i lose
