AWShev wrote:keep an eye out for ae101 4agze pistons and rebuild ur motor with those
then fit ur supercharger / turbo and injectors with aftermarket management
then get a good tune
i know ive exceded ur budget but u would end up with a reliable motor
u could run on 14psi all day
provided the tune is right
Al wrote:Strip it out. Absolutely everything bar the drivers seat.
Replace the leads, plugs, rotor and dizzy cap, air filter, fuel filter with genuine parts (maybe not plugs, some cheap copper NGK's will be sweet).
Run some high 14 second 1/4's.
