sc12 belt question
sc12 belt question
Postby iamawesome » Tue Dec 28, 2010 9:11 pm
jsut got a pulley which is supposed to be 12 psi for my aw11 , how much longer of a drive belt will i need if anyone knows?
iamawesome
Postby FLAWLES » Tue Dec 28, 2010 9:15 pm
man its been ages since i had a 4agze so someone can correct me if im worng
but the belt you have will be fine
only have to change belts when you jump up to the 14psi pulley
FLAWLES
Postby evil_si » Tue Dec 28, 2010 9:57 pm
The 14psi or 175mm kit runs a 5pk 945-965 belt,
A 12psi pulley is about 165mm, and uses a 5pk 925-940
The boost it's running is not always a good indication, as the condition of supercharger and engine are the determining factors,
So dependent on the actual size of your pulley it may be either,
Easiest way is to probably check out the size of the crank pulley,
A 12psi pulley is about 165mm, a 14psi is 175mm,
or can check the gap between the crank pulley and water pump pulley,
if it's a big one there will be approx 1-2mm gap between the two, so use a 5pk 945
It's a 5-8mm gap use the shorter belt
evil_si
Postby evil_si » Tue Dec 28, 2010 10:13 pm
Just re-read your post, easiest way is to measure the out side diameter of the big side of the pulley,
12psi- 165mm 5pk 925
14psi- 175mm 5pk 945
Have you got the smaller tensioner pulley to go with it?
You will need to remove the timing pointer, and fit smaller tensioner pulley for the crank pulley to fit,
evil_si
