Measure Valve Springs?
Postby cat007 » Mon Feb 07, 2011 5:20 pm
Hey all
Just wondering if there's a way to measure the spring rate etc for some valve springs or if there's someone I can take them to and get them tested/measured?
Hunt
Postby Dell'Orto » Mon Feb 07, 2011 6:38 pm
Any head shop will be able to, and I dare say most engine shops will have a valve spring machine
Postby mjrstar » Mon Feb 07, 2011 8:47 pm
Well... If this is for your 1G try this:
Free length : 43.85mm
Compressed length: add 17.5kg's of weight and the length should equal about 34.7mm.
If however this is not for your 1G please ignore.
Spring squareness 2mm
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cat007 » Mon Feb 07, 2011 10:52 pm
mjrstar wrote:Well... If this is for your 1G try this:
Yeah it's for the 1G. I just picked up a set from Allen Waye at Performance Springs .com.au and just wanting to compare what the stock ones are like. Apparently these are the same spec as the TRD ones....
I'll try and measure them tomorrow and see how the new ones measure up :)
Hunt
Postby -Justin- » Tue Feb 08, 2011 7:18 am
Most engine reconditioners should have a valvespring tester of some description. From memory performance springs are normally around 75-90 lb's with factory springs closer to 50-60lbs (On seat pressure), but i could have these numbers wrong it's been a while since i've measured some heh.
-Justin-
Postby cat007 » Tue Feb 08, 2011 8:23 am
Apparently these springs have a spec of:
Standard installed height is 1.400.
These springs are 60Lbs @ 1.400 & 160Lbs @ .920. Coil Bind is .820
The spring rate is 208Lbs per inch.
Postby Bazda » Tue Feb 08, 2011 8:44 am
oh no performance springs..
I had this brand, lasted for about 1 year until they ended up being weaker than the stock ones!
4agtepower on here, his lasted not even a month with high lift cams and big valves.
My dad has a valve spring tester, if you go down he will happily test them for you.
Postby cat007 » Tue Feb 08, 2011 8:52 am
Bazda wrote:oh no performance springs..
Oh really? These are the same ones that Kyle (6boost) used with his 9 second 9,500rpm 1G and they worked well for him....
I guess I'll test them now and in a year's time and see how they're holding up :)
Postby mjrstar » Tue Feb 08, 2011 12:53 pm
Just out of interest are you planning on looking for more power out of the 1G?
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby cat007 » Tue Feb 08, 2011 12:55 pm
mjrstar wrote:Just out of interest are you planning on looking for more power out of the 1G?
I want to get it up to about 260-270rwkw as they can handle that power output without too much struggle. Plus I love the sound of them when they're over 8,000rpm haha
The engine I'm going to be rebuilding over the coming months (or years haha) will have all the oil gallery work etc done so it can support the higher hp without running bearings.
Postby mjrstar » Tue Feb 08, 2011 7:19 pm
Sounds similar to what I have done....
Oh I have a spare set of brand new crank thrust bearings, and a pile of valve shims if you get short on bits...
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
