AE86/5 chassis number on anywhere else apart from firewall?
Postby Di » Thu Feb 17, 2011 8:45 pm
apart from firewall and build plate?
:idea:
Di
Postby soopachargen » Fri Feb 18, 2011 5:03 pm
this reeks of dodgy
When in doubt, down and out.
soopachargen
Postby Akane » Fri Feb 18, 2011 5:48 pm
soopachargen wrote:this reeks of dodgy
I'd still hit it if the price is right tho :lol:
Postby Di » Sat Feb 19, 2011 12:08 am
guess there is no way to check history of the car if both are missing, might just have to take take the words of the seller.
Di
Postby Bling » Sat Feb 19, 2011 12:18 am
You have to wonder why it would be removed from the firewall :?
Postby ~SlideWays~ » Sat Feb 19, 2011 10:07 am
What possible reason could there be to remove the chassis number that is stamped/engraved into the firewall?? Its not like it is just a tag riveted one.
Even if it has had major crash damage and they replaced the whole firewall?
~SlideWays~
Postby DeeCee » Sat Feb 19, 2011 11:38 am
on my celica, the chassis number is stamped on the top metal bar that runs between the headlights.
GT Four Adovansu
DeeCee
Postby Bling » Sat Feb 19, 2011 12:05 pm
AE85/6 is on the firewall..
Postby Rob_GTZ » Sat Feb 19, 2011 12:09 pm
I'm going to guess that he's talking about the white AE86 hatch on Trademe.
It's had Riveted chassis tag removed, and also had the stamped number ground off
Asked the owner some questions & got no real answers, says he knows nothing of the cars history, not even if it has been previously registered or if it is a recent import that is uncomplied.
Absolute waste of time if you're aiming to get it registered.
AE86 had a five digit number stamped into upper Radiator support bar, but it doesn't seem to relate to chassis number in any way
Rob_GTZ
Postby Mr Revhead » Sat Feb 19, 2011 6:20 pm
That car will never legitimately be on the road again. Sounds as dodge as you can get.
There's only one reason for grinding the number off the fire wall
Postby neo » Sat Feb 19, 2011 10:14 pm
Mr Revhead wrote:That car will never legitimately be on the road again. Sounds as dodge as you can get.
it said ae85? :roll:
neo
Postby Bling » Sat Feb 19, 2011 11:50 pm
That's stupid..... why would you bother doing it for that reason.....
Clearly its for weight reduction, the metal dust would have reduced the overall weight quite substantially. 8)
