LEAKER wrote:
Basically unbolt the end housing on the transfer case, remove the old diff setup and replace with my spare set up which i will weld shut. Blank off cv outputs and machine down the old outter cv to bolt through the front hub to keep the wheel bearings tight. Easy to do, cheap and all that.
1I1 wrote:Potential rear axle/diff issues trying to put all of power through rear end instead of spread over front wheels as well as?
Original Poster wrote:How Hard is A front skidda conversion to Rear Skidda?? Any Suggestions
RunningRich wrote:Well you sound like a complete idiot, so I'd have to say that (for you) the conversion would be very difficult indeed.
The easiest way for you to achieve what you want is to drive backwards...
I am seriously considering getting out of the mr2 business...Adamal wrote:The easiest way to convert to RWD is to convert your car to money, and then convert that money into an MR2 or an Altezza or the likes.
BZG|Bling wrote:sergei wrote:"my car handles too well, better drink my own piss"
Well played
Users browsing this forum: Bing [Bot] and 11 guests
