Turbo bolts/studs
Turbo bolts/studs
Postby tsoob » Fri Mar 04, 2011 8:54 pm
I have had to remove my turbo again, and have removed it around 4 times in the last year, I find that the steel studs and bolts that I use get rusted and become a bit of a c@$t to remove
What other options do I have?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby fivebob » Fri Mar 04, 2011 9:45 pm
Just coat them with anti-seize or copper coat, that come apart much easier that way.
Postby Adoom » Fri Mar 04, 2011 10:09 pm
I have brass nuts..... :lol:
Adoom
Postby RS13 » Sat Mar 05, 2011 12:18 am
We use the pure nickel "Never Seez" on nuts/fasteners on the hot section of gas turbines, really good stuff. Or just copper-coat as was said above. Both are very, very bad for you so wear gloves when using though.
RS13
Postby levinguy » Sat Mar 05, 2011 1:03 am
copper coat plus new studs + nuts. shouldnt have a problem? go to the gym?
levinguy
Postby Akane » Sat Mar 05, 2011 11:26 am
I've used the stud/nut combo and all I get is loose nuts falling off and all that kinda bullshit.
Changed them to Allen head bolts for the downpipe and allen head countersink for the adapter, worked a treat, pity turbo to adapter still has to be used with nut and bolt since there's no room there.
Postby matt dunn » Sat Mar 05, 2011 2:34 pm
Akane wrote:I've used the stud/nut combo and all I get is loose nuts falling off and all that kinda bullshit.
Same, i had more problems with them coming loose while in use.
took me ages to get it so i didn't need to check/tighten them each race.
i would rather have them tight than not.
Postby tsoob » Sat Mar 05, 2011 3:53 pm
yep my problem is that they are a pain in the ass to get to, they are siezing, and we used copper last time..
The size of them is a challenge particually the ones on the wastegate, as you cant get a 12mm socket on them.
Also the studs with nuts that the turbo bolts to the manifold have come loose, and i have even lost one of the nuts completley.
what about stainless bolts? will they be more resistant to rusting?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby matt dunn » Sat Mar 05, 2011 5:01 pm
Lol, out of all the nuts and bolts that hold my manifold and turbo on there is on 2 that you can get a socket onto,
and about 3 that you can't get to with a ring ring spanner
and even a couple that you cant get to with an open ended spanner properly.
It really depends on the quality of the nuts and bolts.
I tried all sorts of aftermarket types and ended up with Genuine Toyota Parts
Toyota double length nuts
909170-10035
and I dont have the part number for the studs with me.
Postby Akane » Sat Mar 05, 2011 5:01 pm
It's not so much the rusting, it's the heat cycles it goes through, it stretches them out and when it cools it shrinks back, do this on a daily basis and they just don't like it.
This is what I use, and they don't round themselves out when you put a big booty allen key on it, never had one snapped on me (powerbar + allen key lol).
Postby tsoob » Sat Mar 05, 2011 6:10 pm
yeah i was thinking that allen keys may be the way to go... be nice if i could get a ratcheting allen key..
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Adoom » Sat Mar 05, 2011 9:18 pm
tsoob wrote:yeah i was thinking that allen keys may be the way to go... be nice if i could get a ratcheting allen key..
Errrr, you can. :?
You can get allen key "sockets" for ratchets.... different lengths even.
Adoom
Postby tsoob » Sat Mar 05, 2011 11:46 pm
Errrr, you can. :?
I have those.... I mean a ratcheting allen key.
The problem is that a socket wont fit in the gap remember....
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Bling » Sun Mar 06, 2011 12:19 am
Ratchet spanner with a short length of allen key, enough to go into bolt/spanner, sorted :lol:
Postby Mr Ree » Sun Mar 06, 2011 9:52 am
Hi Tsoob.
If you have a marine shop nearby, pop in with your 1 of each nut/bolt that you need and match it up with some of the love stainless items they have in stock.
No more rust and great quality parts.
P.S As above ^ I use a ratchet spanner and an allen key "bit" to get my WG bolts out as I have about as much room as it sounds like you have.
Mr Ree
Postby Bazda » Sun Mar 06, 2011 10:05 pm
One of my dads mates figured out a good combo on his 700hp bmw targa/circuit car. I think he used alloy studs, and stainless nuts.
I will have to ask him next time I see him, I could be wrong about alloy but it def was 2 diff types of metals, one to expand faster than the other to make better contact.
On mine I use M12x1.25 studs and nuts off a Mitsi Evo. Cant remember which part of the exhaust its off.
M12 is an overkill but def does the trick as i've been using the same bolts/studs for over 3 years now.
Postby tim_blair » Mon Mar 07, 2011 5:37 pm
copper coat or simalar metal based anti seize for heat resistant
stainless is realy good for corrosion resistance
i use "cone lock" or "con loc" nuts on myn to stop them from comming loose
or double nut if there is room
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby Bazda » Mon Mar 07, 2011 6:43 pm
Snore lock washers are the best
