TVIS 4AGE - low oil pressure + others
Postby Santa'sBoostinSleigh » Tue Mar 22, 2011 10:18 am
so I am fixing up a TVIS 4AGE, I assume is a bigport
the factory oil pressure gauge takes bloody ages to come up to pressure, and when you give it a bit of stink it drops right down again
what is this likely to be/indicate?
I solve the problem how?
Hopefully this is easy enough solution as it was planned to be a quick fix and sell on project
otherwise i guess the car would make a good racecar shell and/or donor shell
also some muppet removed the A/C, and the radiator fan stays on - I cant recall the plug i need to bridge to stop this happening, and I havent noticed one in the logical places (from very vauge memory) - wheres the spot to look
(this is assuming that this is what is causing the problem)
and further more, a pod filter has been fitted, so theres a few random vac hoses etc that look like they arent quite in the right place - has anyone got any pics or diags showing what should go where?
last thing (hopefully), the dizzy looks like it leaks a bit of oil - I recall (once again from my shitty memory) that this is common. Is it a problem? how do I fix/tidy it up?
cheers!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Leon » Tue Mar 22, 2011 10:22 am
Disconnect oil guage. Ignorance is bliss. :wink:
Dizzy leak is incredibly common, oil seal on dizzy shaft is usually the cause. If you're going to fix it, remember to mark the dizzy before you pull it out. :lol:
Postby 2LTR Rona » Tue Mar 22, 2011 11:09 am
AC plug is likely to be close to the left strut tower, AC lines should come out of the fire wall and follow the left chassis rail down to the front (if they were / are there)
Leaking Dizzy, very comon issue, had it in the KE, replaced the seal and for added back up used a bit of gunk on there too, no leak after that
2002 Altezza, 1974 KE25
2LTR Rona
Postby Santa'sBoostinSleigh » Tue Mar 22, 2011 11:18 am
all the aircon piping is gone, so i'll just have to find the plug and bridge the wires
I was looking around that area and couldnt spot it last night
Santa's Mega Sale
Postby 2LTR Rona » Tue Mar 22, 2011 11:31 am
same as my trueno then, no piping but still loom /wiring, if i remember i'll take a pic later this afternoon / night of the plug and fire it through to you,
I was lucky enough to still have some of the AC line there with the other half of the pl,ug on it so just chopped it & plugged it in, solved the constant fan problem
2LTR Rona
Postby Quirky » Tue Mar 22, 2011 4:08 pm
Leon wrote:Disconnect oil guage. Ignorance is bliss. :wink:
I had this happen.
Drove the car to the service station, and as it parked it was just pouring oil.
You have to wait for the oil to get up to temperature before it will leak oil, so the first 5 mins shows no signs.
What a fun job it was to fix aswell ugh...
Hello There
Quirky
Postby B1NZ » Tue Mar 22, 2011 4:13 pm
http://www.twincam.org/topic/21555-4age ... eal-guide/
or
http://forums.club4ag.com/zerothread?id=8286
When you get the bits get some for me and fix mine too please ;-)
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Quirky » Tue Mar 22, 2011 4:47 pm
Just go to a bearing shop.
They have every possible seal you can think of.
I paid $6 for one Viton seal.
Should last a great deal.
Hello There
Quirky
Postby CAMB01 » Tue Mar 22, 2011 6:28 pm
Oil pressure sender unit could be faulty and giving inaccurate readings. Some units are known for doing this.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Santa'sBoostinSleigh » Thu Mar 24, 2011 10:21 am
Dont spose theres an easy test for that Cam?
Santa's Mega Sale
Postby CAMB01 » Thu Mar 24, 2011 7:41 pm
Get another one lol. I'm not sure about how to test them sorry.
CAMB01
Postby matt dunn » Thu Mar 24, 2011 9:36 pm
Santa'sBoostinSleigh wrote:Dont spose theres an easy test for that Cam?
testing them properly is about 10x harder and dearer than replacing them.
Postby Santa'sBoostinSleigh » Fri Mar 25, 2011 8:50 pm
while having another 5min nosey at the car tonight, i yanked on the oil pressure sensor wire (gently) and it came off to meet me - it was a bare wire, so assuming was just wrapped around sensor and was covered in oil
found 2 possible plugs for the aircon, but was too lazy to actually check which one was the right one. i should compare my other car to it
Santa's Mega Sale
