Vacuum noise?
Vacuum noise?
Postby EssDub » Tue Apr 19, 2011 12:33 am
http://www.youtube.com/watch?v=gGVucSNZynM
Can anyone help us identify this noise? It sounds like a vacuum leak.
Engine is a gen3 3S-GE transplanted into a 1990 NA Auto. Using all gen2 electrics and gen3 sensors :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby gt4dude » Tue Apr 19, 2011 1:02 am
I've never heard a vacuum leak sound like that before,
I have heard an ST185 transmission sound like that though, not as obnoxious.
And what's with the engine bouncing around like that? Maybe that sound isn't the only thing wrong with it.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby siren676 » Tue Apr 19, 2011 2:32 am
That noise is awful. Could a starter motor sound like that if it was stuck onto the flywheel?
Also why does it sound like a rotary?
siren676
Postby EssDub » Tue Apr 19, 2011 9:14 am
The engine is only on 3 mounts.
EssDub
Postby EssDub » Tue Apr 19, 2011 9:37 am
siren676 wrote:That noise is awful. Could a starter motor sound like that if it was stuck onto the flywheel?
Starter is OK, well clear of the 'flywheel'
Thats another thing it runs rough, but revs really easily...
EssDub
Postby Garreth27 » Tue Apr 19, 2011 12:02 pm
cambelt too tight? sounds similar to what my starlet sounded like when i tighten the cambelt up a bit too much
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby EssDub » Tue Apr 19, 2011 12:18 pm
Dont see how you could overtighten the cambelt on this motor, the tensioner is hydraulic. There was around 10mm deflection between the cam gears.
EssDub
Postby Vertigo » Tue Apr 19, 2011 12:22 pm
the pitch reaches a plateau, which suggests some kind of constant leak after a certain rpm. weird. wouldnt be a wastegate, i dont think? not a belt, tho i could be wrong i guess.
pcv valve?
bhg? :lol:
TVIS just kicked in, yo!
Vertigo
Postby EssDub » Tue Apr 19, 2011 12:35 pm
Vertigo wrote:the pitch reaches a plateau, which suggests some kind of constant leak after a certain rpm. weird. wouldnt be a wastegate, i dont think? not a belt, tho i could be wrong i guess.
Thats what we think, a big vac leak, also could cause it run rough
Vertigo wrote:pcv valve?
hmm...
Vertigo wrote:bhg? :lol:
Don't give us MAGN1T syndrome :D
EssDub
Postby EssDub » Tue Apr 19, 2011 6:57 pm
Interesting, this arvo, we found that by playing with the throttle body itself, we made the noise go away! We had a gasket made up for the TB, but its full of holes, has anyone got a picture of a stock gen3 3S-GE Throttle body gasket?
EssDub
Users browsing this forum: No registered users and 35 guests
