Coolant
Coolant
Postby BZG Wagon » Sat Apr 23, 2011 1:22 am
Do the brands differ? Or can I replace with any ol' red coolant in my GTT (vs. running down to my local toyota dealership - if they stock it)?
I hear the corosion inhibiters break down after a while - is this correct? If so how often are you suppose to flush your coolant?
Oh and is it worth running some sort of radiator flush through the system?
BZG Wagon
Postby YeMs » Sat Apr 23, 2011 8:12 am
the red coolant is good for 100,00ks. as a rule of thumb i always put in what came out. We flush green coolant systems every 40,000ks. We also use a WYNNS Flush and sealant pack with every flush and a flush machine to flush the coolant out. as for brand, i think generally middle-of-the-road price wise is fine. i dont think you need real expencive stuff for a daily, different if it were in a race car that goes through much more extreme heat cycles. and remember to mix it according to the instructions which is usually about 50/50. a stronger mix can do more damage than good.
Your local Hybrid Elite tech
YeMs
Postby fuel » Sat Apr 23, 2011 10:05 am
Nulon is good, you can get it in both red or green coolant at Supercheap. They say it lasts 4/5 years or 250,000kms or something like that, but I change my coolant every 2-3 years regardless of the kms travelled.
LOUD NOISES!!!
fuel
Postby Mr Revhead » Sat Apr 23, 2011 10:21 am
Just make sure you read the labels. Colour is not always an indication of the type.
Postby Dell'Orto » Sat Apr 23, 2011 10:35 am
Prestone stuff mixes with the majority of coolants out there, red or green.
Postby Mr Ree » Sat Apr 23, 2011 10:50 am
Just stick to good old toyota red. Its designed for your motor, and its whats currrently in your motor so its the best choice considering it will last the next 6 years or so.
Mr Ree
Postby BZG Wagon » Sat Apr 23, 2011 12:43 pm
Thanks for the info.
I think I'll go for this stuff: http://www.nulon.co.nz/products/Red_Long_Life_Concentrated_Coolant/
It's $30 from Supercheap vs. $60 for Toyota Super Long Life Coolant (pink - apparently. Also premixed to make it an even worse deal), which Toyota recomended.
BZG Wagon
Postby Akane » Sat Apr 23, 2011 6:35 pm
I had toyota red in the system on one of my other car, didn't flush all out, put in green stuff. bad ending.
Postby solitaire » Sun Apr 24, 2011 1:14 am
where do you get such a huge amount of deminarlised water if you are going with concentrate?
AE92, KZJ120, KDJ120
solitaire
Postby Bling » Sun Apr 24, 2011 1:22 am
You mean from the tap is no good? :lol: :lol: :lol:
Postby Makaveli » Sun Apr 24, 2011 9:05 am
From a Lexus/Toyota workshop manual:
"Use of improper coolants may damage the engine cooling system.
 Only use Toyota Super Long Life Coolant or similar high quality ethlene glycol based non-silicate,
non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology (coolant
with long-life hybrid organic acid technology consists of a combination of low phosphates and organic
acids).
 New Toyota vehicles are filled with Toyota Super Long Life Coolant. When replacing the coolant, Toyota
Super Long Life Coolant (color is pink, premixed ethyleneglycol concentration is approximately 50
% and freezing temperature is -35°C (-31°F)) is recommended."
You can buy distilled water from Supercheap Auto, I think they come in 4L packs? Which makes 8L of coolant.
Makaveli
Postby Rob » Sun Apr 24, 2011 9:21 am
I just looked at this:
http://newcarbuyingguide.com/index.php/ ... event=view
and it seems pretty good
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby RomanV » Sun Apr 24, 2011 11:57 am
Makaveli wrote:non-borate coolant
Postby BZG Wagon » Sun Apr 24, 2011 12:36 pm
My car's 13-ish years old, so I'm not sure whether switching from Red (LL) to Pink (SLL) is the way to go.
The Nulon anitifreeze says it's 'silicate, borate, phosphate, nitrate & amine free' so I don't see how it'll be any different (better or worse) than Toyota LL.
I have always used Toyota Genuine Parts - but I can't see any benefit in spending more for TGP radiator fluid in this situation.
solitaire wrote:where do you get such a huge amount of deminarlised water if you are going with concentrate?
Straight out of the dehumidifer... :lol:
BZG Wagon
Postby solitaire » Sun Apr 24, 2011 12:38 pm
BZG Wagon wrote:My car's 13-ish years old, so I'm not sure whether switching from Red (LL) to Pink (SLL) is the way to go.
I have always used Toyota Genuine Parts - but I can't see any benefit in spending more in this case for TGP radiator fluid.
Pardon my ignorance but is that serious? i have 2 dehumidifiers doing nothing and the air in my garage is moist as on accoutn of the wet clay in the unconcreted portion of my garage, could i just start the dehumifiers going and collect?
solitaire
Postby BZG Wagon » Sun Apr 24, 2011 8:58 pm
I used dehumidifier water in previous cars I've owned - I don't see why it would be a bad thing. Essentially it's gone through the same process of distilling - it's just not purified (so there might be dust, bacteria etc in it).
I supposed you could check the PH to make sure it's neutral? Any chemists out there wanting to share their opinion?
I'll be buying distilled water for my GTT though.
BZG Wagon
Postby Mr Revhead » Sun Apr 24, 2011 9:00 pm
Never heard of distilled water for coolant. I wouldn't be bothering with that tbh
Postby iOnic » Sun Apr 24, 2011 9:06 pm
Mr Revhead wrote:Never heard of distilled water for coolant. I wouldn't be bothering with that tbh
Gimmick to rope in pedantic worrying types. Never seen/heard of a workshop (Toyota included) using anything but tap water.
In theory, yes distilled water is better - in practice, good luck noticing any difference.
Postby solitaire » Sun Apr 24, 2011 9:08 pm
That would be me :D
glad to hear this stuff... i have enough things to spend money on as it is, babies are expensive...
solitaire
Postby BZG Wagon » Sun Apr 24, 2011 9:27 pm
Meh - coolant manufacturers recommend using demineralised water. Auckland water is sh*t - even I don't like having it inside me so why chuck it in my car.
Workshops cut corners and work to the minimum standard to get the job done as quick and cheaply as possible - even Toyota (especially Toyota from my experience). Mechanics I know generally apply a double standard ayway when working on their cars vs. customers cars.
Call me pedantic but I don't mind taking a bit of extra care.
BZG Wagon
Users browsing this forum: Bing [Bot] and 8 guests
