2zzge into ae101 20v levin???
Postby vr4boy » Tue May 31, 2011 5:45 pm
i was going to do a blacktop convertion, but now thinking to be different i may put a 2zz in, has anyone on here tried this? what needs to be changed to make it fit?
Dan
1995 ae101 levin st 20v
vr4boy
Postby Rick » Tue May 31, 2011 6:23 pm
A fair amount of work needed, exhaust is on the firewall side for a start.
Why dont you go 7age?
Postby vr4boy » Tue May 31, 2011 7:26 pm
what head do you use for a 7age? how easy is that to build?
vr4boy
Postby gt4dude » Tue May 31, 2011 8:07 pm
7age needs alot of R&D.
The basic gist of it is a 7a-fe bottom end, 4age head and you need to figure out where your pistons and rods are going to come from, most likely 4age rods and custom height pistons, the right size/toothed cambelt i've heard comes from a porsche 922??? then you gotta figure out your fuelling, most likely using a piggybacked 4age ecu.
you'll be hitting alot of stops during your build as you research and customise/improvise, the end result (in a far from perfect state) will most likely fall well short of a 2zz, so the easiest route would be to save up some cash for a motor and swap with custom mounts and car rewiring
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby d1 mule » Tue May 31, 2011 9:18 pm
do it!!!! i know nothing about the swap but it been needing to be done for ages!!!!!
and a 7age isnt that hard, talk to bazda about it.
7a block, aftermarket rods, either 4age or aftermarket pistons, whatever head you want, cambelt varies between 16v & 20v heads.
d1 mule
Postby Leon » Tue May 31, 2011 9:31 pm
there's a guy doing 2zz into AW11 on the NZ MR2 Club forums ... he even has a build thread on it
Wouldn't be miles different I suspect
http://mr2.org.nz/phpbb3/viewtopic.php? ... c5986f8f2f
Postby vr4boy » Tue May 31, 2011 9:38 pm
cool, also does anyone no if the 2zz will bolt up to my c56 gearbox? or even will the c60 6 speed the 2zz came out with bolt straight in to my car so i only have to make an engine mount and use factory gearbox mounts.
vr4boy
Postby touge_ae101 » Tue May 31, 2011 10:12 pm
yeah 2zz will bolt up to c56 or you could use the 6 speed and it wouldn't be too far out as it uses a c-series housing. everything is the same like i'm using a 2zz TRD clutch in my car atm with c56.
i have thought about doing this quite a bit i'm sure it wouldn't be hard to do and would really make the car come alive. but be aware it will take a lot of effort as simple things like fuel lines etc will be on the wrong side of the engine since it faces the opposite way to a 4a. you should do it!
finding a 2zz might be another problem as there doesn't seem to be many floating around...
touge_ae101
Postby vr4boy » Tue May 31, 2011 10:39 pm
yea going to have a chat to a auto sparky mate tomorrow about wiring, i no of a 2zzge, just not sure what they want for it.
vr4boy
Postby rx7guy » Tue May 31, 2011 10:40 pm
Leon wrote:there's a guy doing 2zz into AW11 on the NZ MR2 Club forums ... he even has a build thread on it
Yeah I helped him with, its hilarious how easy it was really. We kept thinking something wouldnt work but it all just did.. The exhaust was the hardest part and could be tricky to fit on a fwd
The torque band is wide and the road is narrow
rx7guy
Postby Bazda » Wed Jun 01, 2011 2:55 pm
2zz into a fwd ae series chassis is pretty easy actually.
You only need to modify the drivers side mount, using the orginal 4a mount to bolt it to the 2zz eng mounting point. As you can bolt up the original C series g/box and use 3 of the original mounts. Also some removal of section from the north/south x member and boxing it up to clear the sump etc.
If I was to start again I would def go for a 2zz after seeing how easy it is to fit.
Postby h8wrxs » Wed Jun 01, 2011 5:08 pm
how well do the 2zzge's go?
ive heard of them but know nothing about them
for example my plan is to do a simple 4agte 20v motor in my trueno just with a small s15 silvia turbo, would a 2zz keep up with that?
h8wrxs
Postby 1I1 » Wed Jun 01, 2011 5:16 pm
Craig (bones_on_bikes is his user name on here) was able to hold off a Ralliart Lancer on the straights at Manfeild in his RunX. That was with a stock 2ZZGE + pod filter + cat back. About 110-115kw @ wheels I think.
TRD Clicky >>Here
1I1
Postby Bazda » Wed Jun 01, 2011 5:44 pm
Im sure a Turbo 20v eng will be much more powerfull than a stock 2zz.
If your turbo the 2zz then thats a diff story.
Postby Leon » Wed Jun 01, 2011 6:09 pm
I'd love somebody to put a 2zz into my club car (AE92) ... + turbo wouldn't really suit though, as multiply cc rating x 1.7 for MSNZ class ratings
Postby ch4ng » Wed Jun 01, 2011 6:25 pm
h8wrxs wrote:how well do the 2zzge's go?
ive heard of them but know nothing about them....
From what I've driven they go (and sound) like a Honda B18CR
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Nuty|Mike » Wed Jun 01, 2011 6:30 pm
Guys in the states put them in mr-s all the time simple Intake and exhaust mods usually getting them mid to high 13's on the 1/4 .
Used to jet my fat fielder wagon around quite well once in lift no power below tho ....imo needs 6 speed gbox to be any use .
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Leon » Wed Jun 01, 2011 7:12 pm
don't MRS' come out with 2ZZ engines anyway?
Postby rx7guy » Wed Jun 01, 2011 7:17 pm
Leon wrote:don't MRS' come out with 2ZZ engines anyway?
nope, only 1zz
rx7guy
Postby Leon » Wed Jun 01, 2011 7:20 pm
gutted! I'd always assumed they had the good engine.
Users browsing this forum: Bing [Bot] and 29 guests
