3sgte clutch into beams?
Postby iamawesome » Tue Jun 14, 2011 6:43 pm
Someone off trademe wants to know if my 3sgte clutch will fit in his beams st202. Would it work? Keen to get some cash for it. Could my flywheel bolt on and use it? Help appreciated thanks
iamawesome
Postby strx7 » Tue Jun 14, 2011 10:04 pm
the clutch spline wont be the same unless its got an E series box?
Postby RomanV » Wed Jun 15, 2011 12:02 am
Yep what he said.
Confirmed by learning the hard/expensive way.
Postby iamawesome » Wed Jun 15, 2011 10:25 am
Damn thanks guys
iamawesome
Postby Malcolm » Wed Jun 15, 2011 10:45 am
Get him to check his gearbox code - I thought the SS3's had E series boxes (which it will work with)
Postby Malcolm » Wed Jun 15, 2011 10:49 am
quick google turned up these pics which, assuming they're from an SS3, show it's an S5* and therefore wont work
http://www.facebook.com/media/set/?set= ... 96&l=67dae
Postby xsspeed » Wed Jun 15, 2011 11:20 am
Think you are right there Malcom, SSIII with beams 3s I think had the E56. (possibly not all of them?)
Point of interest SW20 with beams 3s had S54.
I recently found this out, as bought a S54 with lsd from an sw20 (ex Roman, then Spencer I beleive?), when trying to track down shifter mechs to suit FWD I found that the gearboxes in the SSIII's all seemed to be E series.
Postby ®usty » Wed Jun 15, 2011 6:56 pm
There was no factory 'E' series gearbox in the SS-III.
SS-II
SS-II (1994-1997)
S54-06A LSD type: none
SS-II Convertible
SS-II Superstrut edition (1994-1995)
E56-04C LSD type: Viscious
SS-II BEAMS (1997-1999)
SS-III
SS-III Superstrut (1995-1997)
S54-06D LSD type: Helical
SS-III Superstrut BEAMS (1997-1999)
®usty
