LED Dashboard lights
Postby GDII » Mon Jun 27, 2011 8:25 pm
Has anyone used LED replacements for dashboard bulbs like these?
http://www.superbrightleds.com/cgi-bin/ ... ument.html
I know that LEDs don't direct light the same as incandescent bulbs. My dash uses the standard plastic optics to distribute the light to the guages. Not too sure if these would work well enough.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby loudstealthGT-Four » Mon Jun 27, 2011 9:18 pm
yip ive swapped all the lights in my dash with LED's ill take some photos and post them up
these are the bulbs that i used - http://ledstuff.co.nz/product_info.php?products_id=274
Last edited by loudstealthGT-Four on Mon Jun 27, 2011 10:01 pm, edited 1 time in total.
loudstealthGT-Four
Postby loudstealthGT-Four » Mon Jun 27, 2011 9:54 pm
loudstealthGT-Four
Postby AE82 FXGT » Mon Jun 27, 2011 10:55 pm
that turned out mean, would defo do that to my gtz if i still had it.
AE82 FXGT
Postby GDII » Tue Jun 28, 2011 9:04 am
That looks good. The LEDs you used would have a better effect than the ones I was looking at. Except they don't have a large range of colours.
1990 SW20 MR2
GDII
Postby Girvs » Tue Jun 28, 2011 9:25 am
We just did a small group buy (Snaps ordered these) for some of the MKIV owners. I think everyone so far is quite impressed with them. I'm yet to upgrade my reverse lights to LED's. If I remember I'll put up photos once done.
Girvs
Postby Snaps » Tue Jun 28, 2011 10:59 am
^ Yep, mine turned out amazing (well, for the gauge cluster anyway), and Luke seemed extremely happy with his.
I'm not sure I would recommend using the Neowedge bulbs in anything like the Air Conditioning controller backlighting - the light just comes out uneven. The Edge base bulbs work perfectly in the places they fit, though.
I haven't got any good pictures of the finished product of mine, but I'll try and snap some pics tonight and get the up here. :)
Cheers,
Brandon
2000 ZZT231 Manual Toyota Celica
Snaps
Postby GDII » Tue Jun 28, 2011 11:58 am
It would be cool to see more photos of them. Now I just have to pick a colour I like.
I painted the incandescent bulbs red in my EE90 corolla and it came out pretty good. But LEDs might look better.
1990 SW20 MR2
GDII
Postby loudstealthGT-Four » Tue Jun 28, 2011 10:17 pm
My lights in my dash are actually a darker blue, but for some reason couldn't get the camera to get the right colour
loudstealthGT-Four
Postby GDII » Wed Jun 29, 2011 8:57 am
Cameras don't always get the same image as what you see with your eyes. Can you see the slight green between 6-7krpm and 40-60kph in the first photo you posted or is that just what the camera picked up?
1990 SW20 MR2
GDII
Postby loudstealthGT-Four » Wed Jun 29, 2011 11:40 pm
yip its green in that section
loudstealthGT-Four
Postby KwS » Thu Jun 30, 2011 7:25 pm
GDII wrote:Cameras don't always get the same image as what you see with your eyes. Can you see the slight green between 6-7krpm and 40-60kph in the first photo you posted or is that just what the camera picked up?
Thats the "sweet as speed bro" section.
KwS
Postby gt4dude » Fri Jul 01, 2011 6:31 am
ive looked into this, the ones from the ledbulbs guy are of decent quality, not the best for light spread, but they seem to last a while before they blow.
a trick is sometimes the pins are bent the wrong way, if u correct them, they line up well and make a better seal inside the contact, this fixes flickering ones.
probably the best ones in nz, ive tried all the china crap, they all either blow or they are too dim
that superbrightleds site though, the americans in their forums seem to recommend them, but ive never bothered to import any to see
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby sergei » Fri Jul 01, 2011 9:20 am
gt4dude wrote:ive looked into this, the ones from the ledbulbs guy are of decent quality, not the best for light spread, but they seem to last a while before they blow.
LEDs blowing is big sign of something really wrong (they using wrong resistors or not using any current limiting and wiring whole bunch in series). A LED should last you decades if not centuries.
Postby GDII » Fri Jul 01, 2011 9:38 am
That's what I thought. LEDs last for a very long time if they are used correctly. That's one of the reasons I want to use them. I don't feel like having to remove the gauges every time a bulb goes out.
The bulb that lights up the temp gauge and half the tacho has been dead for 3 years and when I took the gauges out to fix my lazy tacho I completely forgot to get a new bulb. Grrr :evil:
I like the American LEDs I linked to better than the NZ ones. I think I will go with Red as I have been going with a Black and Red theme for the car lately.
1990 SW20 MR2
GDII
Postby gt4dude » Fri Jul 01, 2011 11:09 am
I think it has to do with the heat sinks, the ones from the ledbulbs guy have heatsinks and the plastic is hard,
with the chinese ones from trademe and various places when they've blown, generally when you pull them from the socket half the bulb is melted around the contact pins, if its a multiled generally the SMT will be fried, the regular leds will be dim, etc
200AWKW / 370NM
gt4dude
Postby GDII » Thu Jul 21, 2011 9:31 am
After replacing the dead bulb with a 5W I think I will just buy 3 more 5W bulbs for the rest of the dash. I can't tell what the old bulbs are, all the say on them is Toshiba but they are quite dull and the 5W bulb makes the gauges and needles brighter more crisp.
Also on a side note the repco brand bulbs seem to go black on the inside after a sort while. Especially in the front park lights. When I install them they are clear. Is this normal or could there be something wrong?
1990 SW20 MR2
GDII
Postby sergei » Thu Jul 21, 2011 1:35 pm
GDII wrote:After replacing the dead bulb with a 5W I think I will just buy 3 more 5W bulbs for the rest of the dash. I can't tell what the old bulbs are, all the say on them is Toshiba but they are quite dull and the 5W bulb makes the gauges and needles brighter more crisp.
It is a sign of really cheap bulb - the black is oxide deposits, which means there is oxygen in the gas inside of the bulb.
Postby Mr Ree » Thu Jul 21, 2011 1:52 pm
You can see the blue bulbs struggle to light the redline section of the tacho in this shot.
The AC buttons are far more blue in the flesh
A bit blurry but shows the difference between the T10 wedge blue, and the blue of the soldered in AC buttons
wak thud gush!
Mr Ree
Postby GDII » Thu Jul 21, 2011 3:14 pm
Haha. What brand would you recommend to use? I would like bulbs that don't do that. They also don't seem to last very long.
1990 SW20 MR2
GDII
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
