I've found a complete setup from a SA60 Celica, what parts will I need other than the obvious Pump, brackets, lines and rack? I'm wondering about the steering column specifically, I haven't pulled mine apart/got the new setup and don't know if it's a different part? Also steering arms?
I'm sure you'll let me know if my question needs clarification (as it usually does
Thanks
