Adhesive Steel to Aluminium suggestions.
Postby ~SlideWays~ » Sat Jul 02, 2011 4:15 pm
I have removed the sun roof from my Trueno and looking at covering the hole with a sheet of Aluminium.
Can anyone suggest what sort of adhesive to use? I'd rather not weld or rivet it because it is likely to warp with the heat or have an uneven surface with rivets.
~SlideWays~
Postby strx7 » Sat Jul 02, 2011 4:57 pm
panel beating seam sealer
Postby atmosports » Sat Jul 02, 2011 7:04 pm
sikaflex do a panel adhesive used in the coachbuilding/boat building industry for bonding panels not sure what it's called cause it's been a while since I used it but not the easiest to remove if you ever want to get the panels off again
atmosports
Postby Mr.Phreak » Sat Jul 02, 2011 7:26 pm
JB Weld :lol:
Mr.Phreak
Postby tim_blair » Sat Jul 02, 2011 8:04 pm
use MS1 wind shield adhesive from wurth
its the most powerful and strongest stuff ive EVER!! used (i work as a mechanical engineer) i use it for just about every adhesive job i do and its especially good on aluminium and plastics
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby Brawler » Sat Jul 02, 2011 8:51 pm
Take it somewhere and get it done, i could see this turning hore
zing! Sig got nuked. Sorry bout that.
Brawler
Postby Adoom » Sun Jul 03, 2011 12:36 am
THIS!
SEXYNESS WIN!!!
Adoom
Postby sergei » Sun Jul 03, 2011 10:22 am
whole bunch of rivets + epoxy.
Postby Adoom » Sun Jul 03, 2011 11:28 am
sergei wrote:whole bunch of rivets + epoxy.
The rivets will have to be EPIC lined up or it will look terrible.
Measure, mark and centre punch every hole perfectly.
Adoom
Postby tim_blair » Sun Jul 03, 2011 3:22 pm
dont use rivets or epoxy
tim_blair
Postby ~SlideWays~ » Mon Jul 04, 2011 10:19 am
Have cut out the alloy sheet now, so since I needed to go to Bunnings I asked a guy there and he tried to help but nothing looked suitable.
I'll have to try Repco after work.
Tim Blair, any suggestions on what to use? Brand type or name of product?
~SlideWays~
Postby ~SlideWays~ » Mon Jul 04, 2011 10:20 am
tim_blair wrote:use MS1 wind shield adhesive from wurth
Actually nevermind my last post, just saw your suggestion. So is Wurth MS1 suitable for steel to aluminium with little to no gap?
~SlideWays~
Postby Bazda » Mon Jul 04, 2011 10:33 am
3M make some pretty good double sided adhesives.
I would give this a go first. Go down to your local 3M supplier.
Postby ~SlideWays~ » Mon Jul 04, 2011 12:41 pm
Looks like there is a 3M supplier up the road from work, I'll go for a walk and see if they can help.
~SlideWays~
Postby tim_blair » Mon Jul 04, 2011 2:44 pm
ill steal you a tube of ms1 from my work if i can find one
seriously its the strongest stuff ever
there will be a tiny .5-1mm gap between depending on how hard you push them together my number is 0212744404 gimme a txt tonight to remind me and ill try get you a tube
tim_blair
Postby ~SlideWays~ » Tue Jul 05, 2011 11:10 am
Cheers Tim, and very nice AE111! 8)
~SlideWays~
