1uz fuel pressure reg
Postby tomtom » Sun Jul 10, 2011 1:27 pm
hi does any1 know what i should set my aftermarket f.p.r to on my 1uzfe? im thinking about 40 psi?
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby Grrrrrrr! » Sun Jul 10, 2011 1:41 pm
Whatever the injectors were designed to operate at. You have changed the injectors right?
Grrrrrrr!
Postby evil_si » Sun Jul 10, 2011 2:29 pm
About 32 from memory, if it's too high it will run rough and bog on acceleration
evil_si
Postby matt dunn » Sun Jul 10, 2011 8:41 pm
Normal pressure would probably be 3 bar or 45 psi with no vacuum on the regulator, so will be less at idle.
