Oil gathering in 4AGZE channel
Postby tuff86 » Sun Jul 17, 2011 7:45 pm
I've got a rwd setup with t3/t4 turbo and it runs fine, just every 4-5000km there gets a fait bit of oil down where the spark plugs go, freaked me out the first time i noticed it, the leads were swimming in the stuff, anyone had this issue or knows how to avoid this happening again? I've replaced the cam cover seals twice now just to make sure they weren't faulty but still doing it?
Current: AE86 Corolla GT, Hyundai Veloster Turbo & Santa Fe
Previous: Lots of Toyotas and a few others
tuff86
Postby Rick » Sun Jul 17, 2011 8:08 pm
Did you use sealant in the corners of the cam cover seals where it goes over the cams??
Postby XSVWGN » Sun Jul 17, 2011 9:26 pm
my 20v did this. The rubber seal around where the spark plug sits wasnt on properly. Adjusted it and problem solved
Matt
2008 Kia rio - work car
XSVWGN
Postby tuff86 » Sun Jul 17, 2011 9:29 pm
didn't use any sealant, i guess thats worth a try, there are no visible signs of oil leaks, i suppose it would be hard to tell unless the oil was filthy but
tuff86
Postby bluemaumau » Mon Jul 18, 2011 7:56 pm
manuals say to use a blob (couldnt think of better term :lol: ) on the meeting point of the cam cover surface and cam retainer. - hope ive used correct terms
Postby Rick » Mon Jul 18, 2011 10:41 pm
This is for a 20V but you get the idea :)
Postby tuff86 » Tue Jul 19, 2011 3:44 pm
Cheers Rick, you're a legend, will give that a go once i've got the non vented cam cover modified for another breather.
tuff86
Postby mega4a » Wed Jul 20, 2011 11:20 am
are you putting presure into the rocker cover via pcv valve from intake to rocker cover?
mega4a
Postby tuff86 » Wed Jul 20, 2011 1:58 pm
Na, all that stuff is gone, i don't even have a cold start injector any more, its still running the standard 1 sided breather but, will get the other cover breathing as well and try that out.
tuff86
