manifold build - oval port, round pipe?
Postby DeeCee » Thu Jul 28, 2011 12:07 am
I'm looking to build a manifold and the exhaust ports are oval on the head and on the flange. Are oval to round sections of pipe able to be purchased or how do you turn round pipe into an oval?
Cheers, DC
GT Four Adovansu
DeeCee
Postby Grrrrrrr! » Thu Jul 28, 2011 12:50 am
Squish in vice/press is one way. Heating it to soften it may help (red hot, not just warm).
Slit pipe, bend open and weld in a wedge is another.
Grrrrrrr!
Postby Ant » Thu Jul 28, 2011 1:34 am
Squashing is yuck
do this instead?
Ant
Postby Sam-Q » Thu Jul 28, 2011 1:51 am
Ant wrote:Squashing is yuck
do this instead?
wow! do you have any more pics?
My website: s-86.com
Technical guides, conversion parts, etc..
Sam-Q
Postby Ant » Thu Jul 28, 2011 2:10 am
For the record, its not my work...
http://www.oldschool.co.nz/phpbb/viewto ... 17&t=10355
http://garage4ag.wordpress.com/
look through here etc.
Ant
Postby strx7 » Thu Jul 28, 2011 10:36 am
has anyone tried doing that with steampipe????
Just squash it with press/vice and when you do put something solid inside it that is the right size you want to squash down to so it acts as a guide/support.
Postby Distrb » Thu Jul 28, 2011 12:29 pm
Just a bit of vice work, used the right sized wedge in the centre, with some good heat and appropriate sized wedge with BFH to finish.
Distrb
Regular Poster
Postby Sam-Q » Thu Jul 28, 2011 1:02 pm
I will thanks, I know it's a bit crude but I like this sort of thing.
Sam-Q
Postby Bling » Thu Jul 28, 2011 8:54 pm
That wedge method is sweet. Simple but works so well, just depends if the height of the oval section matches the diameter of the round section as to if that would work or not I guess.
Postby LEAKER » Thu Jul 28, 2011 9:14 pm
i was reading a article from a guy who made exhaust headers for a living and he said that it didn't matter as long as the pipe was slightly larger overall than the size of the hole in the exhaust flange. Not sure if it helps your quest but a useless piece of info none the less.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby evil_si » Thu Jul 28, 2011 10:09 pm
i made some tooling awhile ago to press steam tube to suit a particular exhaust port, worked well,
you can also buy steam tube reducers, eg 1.1/4 to 1.1/2 the press the larger end to an oval
evil_si
Postby Sam-Q » Thu Jul 28, 2011 10:54 pm
evil_si wrote:i made some tooling awhile ago to press steam tube to suit a particular exhaust port, worked well,
any chance of a picture of this tooling? I am really interested to see how you did it.
Sam-Q
