kp60 engine conversion
Postby slighty_looney » Sat Aug 06, 2011 11:24 am
Hey guys, i know this has proberly been covered before but i cant seem to find it, anywho
Has anyone or is it possable to run a gt starlet motor in a kp starlet? and what issues etc come with it, any help would be really good even gearbox ideas etc, dont want to go 4age, cheers
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby RS13 » Sat Aug 06, 2011 11:42 am
Yeah there is one in Chch floating around, W58 from memory.. haven't seen it for years.
RS13
Postby wde_bdy » Sat Aug 06, 2011 11:45 am
Been done, not a cost effective engine swap. Will cost you the same/more than a 4AGE due to issues with engine mounts (no easy points on the block), custom bellhousing and I think the sump needs a lot of work too. Then you have modified manifolds as well to suit the RWD to end up with still only running 1300cc. If you are a particular fan of the 4E-FTE then go for it but don't expect value for money out of the swap.
Callum
wde_bdy
Postby loose_unit » Sat Aug 06, 2011 4:16 pm
viewtopic.php?t=62472&highlight=4efte
Im the owner of this now. Doesnt look like sump has needed modifying and engine mount adapters dont look super crazy. The bellhousing mods do look like they would have cost a bit however, chop and weld type thing.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby slighty_looney » Sat Aug 06, 2011 9:18 pm
Sweet az, thanks guys, welding and fab work is no issue at all,
FC3S
slighty_looney
Postby Adoom » Sun Aug 07, 2011 9:56 am
Have you considered alternative RWD engines?
Most rwd engine conversions will involve similar amounts of work.
You just have to consider parts availability and what stuff costs.
A 4EFTE will be cool, but HOW MUCH is that specially made fwd->rwd gearbox adapter going to cost? It would save you a lot of hassle and money to get and engine/gearbox that is already the right way around.
A BP(1800) engine out of an MX5? Not as old as some of the other options we have. You can use the MX5 RWD box and get a BPT engine from a GTX familiar. Factory turbo ftw!
I am running a CA18ET(Old SOHC version of the CA18DET). The einge was free..... Not so common enough anymore if you want to be able to get all your spares from scrap yards though. Even the CA18DET..... I've not seen one of those at Pick a Part for YEARS!
It was an easy fit in the hole though. Didn't have to cut anything, other than what was required to convert to hydraulic clutch, and moving the gear lever hole.
I originally tried to keep the cable clutch, but it was fail.
Or an SR20DE*..... but it may be a bit big. Dad has one in an escort, and the engine bay is REALLY FULL. But there is someone on here who has a KP with an SR20DE in it.... Burning Angel??
Adoom
Postby Dell'Orto » Sun Aug 07, 2011 7:52 pm
Couple of random ones on Club K...SR20, EJ20, 13BT
Postby Adamal » Sun Aug 07, 2011 8:01 pm
12A pp
Postby slighty_looney » Mon Aug 08, 2011 7:13 pm
one rotarys enuff, maybe a 3s altezza and box combo lol, just want to do something diffrent, its for my father btw, he owns a quick sr20 not really into cross breading motor car combos really eather,
FC3S
slighty_looney
