Haltech E6K on blacktop
Postby R.U.F » Fri Aug 12, 2011 12:35 pm
Hi all. More questions relating to my planned black top install to my AE85.X.
Has anyone used a Haltech E6K with coil over plugs?? Is it a straight forward set up? I havebeen offered the ecu from a friend at a good price and wonder whether it is a better solution than firewall mods or distributor relocations.
Drive it like you hate it!
R.U.F
Postby strx7 » Fri Aug 12, 2011 1:50 pm
i'm 99.9% sure it can be done with 4 coil packs, or just run a Evo type coil pack and run wasted spark.
on my 5SGTE i used a distributor as a CAS and made up a slim "cap" for seal it all off.
Postby R.U.F » Fri Aug 12, 2011 2:48 pm
Does the evo coil pack alternate the signal for two fires? DId you mean with the standard ecu? I got told the later WRX coils are the same. any chance you know. I have access to cheap (possibly free Subie parts)
R.U.F
Postby R.U.F » Fri Aug 12, 2011 2:52 pm
the above might be a retarded question you probably meant instead of C.O.Ps but can't blame me for being ever hopeful.
R.U.F
Postby strx7 » Fri Aug 12, 2011 5:17 pm
yeah you could use a 4 post 3 wire subaru coil pack, put the E6K into wasted spark mode, you'll still need an external ignitor to fire the coils (i'm pretty sure)
Postby R.U.F » Fri Aug 12, 2011 10:34 pm
R.U.F
Users browsing this forum: Bing [Bot] and 6 guests
