slipping auto?
slipping auto?
Postby deaf_rattle » Tue Aug 16, 2011 9:46 pm
OK, i have pretty much no reverse and hardly anything above second gear.
1st is fine and second is mostly ok.
Is this a sign that the auto is stuffed, or just a sign that something isnt correctly working (ie blockage in lines, filter etc)
Looking into options at the moment, including possibly converting to w57 while im in chch.
but if the auto can be sorted cheaply and quickly, then i might stick with it.
reading into options that make the box stronger..
http://www.supraforums.com/forum/showth ... -a340-last
Postby MrOizo » Tue Aug 16, 2011 9:52 pm
Smell the fluid to see if its burnt!
Was like when the transmission went in the work wagon. Suggestions are that nissan eeither didnt fill with correct fluid or didnt hook a solenoid up properly or at all
MrOizo
Toyspeed Legend
Postby solitaire » Tue Aug 16, 2011 10:15 pm
I had very similiar symptoms and the problem was i filled the tranny (after draining) without the engine running, checked it with the engine running and it was below the low marker on the dip stick.
filled to the correct level and it was good as new again
AE92, KZJ120, KDJ120
solitaire
Postby deaf_rattle » Tue Aug 16, 2011 10:19 pm
MrOizo wrote:Smell the fluid to see if its burnt!
fluid smells burnt thats for sure
Postby solitaire » Tue Aug 16, 2011 10:30 pm
Mine was like that, I had to put about 12 litres through it by draining and refilling (and driving a little bit to mix it up)
solitaire
Postby Stu- » Tue Aug 16, 2011 11:06 pm
Did you use a different torque converter with the recent trans swap?
Project Thread
Stu-
Postby deaf_rattle » Tue Aug 16, 2011 11:10 pm
Stu- wrote:Did you use a different torque converter with the recent trans swap?
same t/c
it was good for the first 100kms, then slipping as per the old trans. got worse and worse as i got further down the island
Postby limbo » Tue Aug 16, 2011 11:58 pm
I just sold my W55, I have two R154 pressure plates and that brass button clutch and the old release bearings and carriers if you go the R154 route on the cheeps
limbo
Users browsing this forum: Bing [Bot] and 6 guests
