Wasted Spark on a K Series - Oil Pump Drive Replacement?
Postby wde_bdy » Thu Oct 20, 2011 12:22 pm
Ok, so have an EDIS setup for my 4K-E to do wasted spark with the MS-II. This means I only need a 36-1 trigger wheel and no dizzy, however K series dizzy drives the oil pump. Has anyone done a cut down dizzy to retain the drive? Any pics or tips appreciated, don't have a spare dizzy yet to play with. I assuming cutting it down will be relatively easy, then just need to cap it and ensure the shaft can't move up and down.
Also, anyone attached a trigger wheel to the back of a K series crank pulley?
Callum
wde_bdy
Postby strx7 » Thu Oct 20, 2011 2:03 pm
put the guts off a 3SGE/3SGE/2JZ/2TZ etc etc dizzy ontt/into the K series dizzy
Postby wde_bdy » Thu Oct 20, 2011 2:34 pm
The Toyota stuff is more hassle with the MS-II, EDIS is very easy to set up. Already have all the coil/module/sensor to do it, just need to retain the oil pump drive.
Callum
wde_bdy
Postby Dell'Orto » Thu Oct 20, 2011 6:22 pm
Would just get an alloy cap made up like the 20v conversion ones
