Glow plug issue
Glow plug issue
Postby gleem » Mon Oct 24, 2011 3:56 pm
Finally got my camry sorted since water went through the entire fuel system. I had to replace all glow plugs at the time. Cars stars perfectly now but the glow plug light goes out and the 5 or so seconds later it comes back on and stays on.
My question is can i disconect the wire to them and put it back when i get around to fixing the issue?
gleem
Postby rollaholic » Mon Oct 24, 2011 6:25 pm
by wire you mean the 12v feed to the actual plugs?
you can, but it'll make it a bitch to start.
Postby gleem » Mon Oct 24, 2011 8:59 pm
yeah thats allright, As long as it does no damage to anything
gleem
Postby matt dunn » Mon Oct 24, 2011 9:11 pm
did you use the correct glow plugs?
Usually if the glow light flashes it is wrong plugs, or a bad temp sensor?
But leaving the wire off the plugs wont affect much
except possibly wear the starter out trying to get it to start.
Postby gleem » Mon Oct 24, 2011 9:14 pm
yes matched the ones that were in there, and tested them, the first one get orange hot in a matter of seconds ( closest to the wire ) than the other 3 are connected by a metal bracket. The end one gets hot when earthed but not orange which is a bit strange
gleem
Postby matt dunn » Mon Oct 24, 2011 9:35 pm
gleem wrote:yes matched the ones that were in there, and tested them, the first one get orange hot in a matter of seconds ( closest to the wire ) than the other 3 are connected by a metal bracket. The end one gets hot when earthed but not orange which is a bit strange
Yeah as they should all heat to the same amount at thge same time.
There will be a current sensing piece in there somewhere too probably.
Users browsing this forum: Bing [Bot] and 29 guests
