loation of the neutral start switch 4age BT
Postby magweal » Tue Oct 25, 2011 10:24 pm
Does any1 know where the neutral start switch is on a AE101 black top. i'm running a man ECU with a man box but auto looms and not starting, not even the check engine or oil lights on the dash. I'm think of by passing the switch and open circuit relay for the fuel pump
magweal
Postby allencr » Wed Oct 26, 2011 6:15 am
Most if not all automatics have them on the box, combined with the reverse switch, and it will be inline with the selector.
allencr
Postby magweal » Wed Oct 26, 2011 6:37 am
That would explain why I can't find the reverse plug to, do we know the plug looks like ie how many wires go to it
magweal
Postby strx7 » Wed Oct 26, 2011 6:41 am
it is all part of the inhibitor switch
Postby Quint » Wed Oct 26, 2011 7:54 am
Maybe a yellow round plug, two wires, iirc, one goes to the starter motor, or a relay nearby, i think, it's pretty easy to find, tbh.
Quint
Postby sergei » Wed Oct 26, 2011 7:58 am
it will be a gray or black, wide multi-pin switch, that normally lives on gearbox (in area under the battery).
On AE101 it is possible to insert a fuse to into the switch to short the the NSW. Not sure on AE111.
Postby magweal » Wed Oct 26, 2011 7:28 pm
Ok kool I think I know the 1 u mean its fairly big grey 1 with yellow plastic in the middle, 4-5 wires out of it. Would that solve the dash lite issue
magweal
Postby sergei » Wed Oct 26, 2011 8:23 pm
I just noticed that you are running manual ECU with auto loom.
I am not sure about AE111 but I am 100% with AE101 they are not plug and play, even if plugs fit there is huge chance that ECU will not run as the pin out could be different.
Postby magweal » Wed Oct 26, 2011 10:31 pm
They are I have a pin out 4 both at and man the only difference is the 2 plugs for the auto. When I figure out how to post pics ill up them up
magweal
Postby magweal » Thu Oct 27, 2011 10:47 pm
I can't belive how easy that was just had to bridge 2 wire in the plug. No just the exhaust and vacum-fuel lined 2 go
magweal
Users browsing this forum: Bing [Bot] and 29 guests
