1997 caldina gtt pinking?
Postby MRDOCA » Mon Oct 31, 2011 10:10 pm
Hey so recently bought this car after a very long run with Mazda familia turbos. It's nice to drive etc but have noticed its pinking/pinging quite abit at about 21/2 -3000 rpm. I'm running 95, so if the ecu isn't retarding the timing would it be safe to say the knock sensors had it? Or will this be something else? How do I check it out?
Thanks
1997 Caldina GTT, Manual, TEIN adjustable suspension, turbosmart bov, 3" exhaust ***Work in progress***
MRDOCA
Postby BZG Wagon » Mon Oct 31, 2011 10:17 pm
Run 98 for starters.
When mine was pinking it was due to a broken air intake sensor.
Pull the efi relay / fuse thing too - imo it can run better after that (or disconnect the batt for a few mins).
BZG Wagon
Postby sergei » Tue Nov 01, 2011 8:09 am
How do you drive it?
Try giving it more rpms on higher loads (use lower gears).
If you never use the power the engine will carbon up. So stop nana-ing it and take it for good drive ;).
Always use 98.
Postby MRDOCA » Tue Nov 01, 2011 9:02 am
I don't nana it trust me lol. I don't believe having to run 98 is the only way to fix it. It shouldn't need 98. I'll check the sensors And unplug battery and reply after
MRDOCA
Postby Alex B » Tue Nov 01, 2011 9:37 am
It's built for 100, run 98.
From memory they are fairly high compression for a turbo.
Postby cedwards » Tue Nov 01, 2011 10:14 am
They don't like anything less than 98, piston shape and high compression are to blame
cedwards
Postby RunningRich » Tue Nov 01, 2011 10:19 am
MRDOCA wrote:It shouldn't need 98.
Stop listening to the media harping on about most cars don't need anything higher than 91.
It was designed for high quality 100 octane. It is a high performance turbo engine with resultant high pressures and temperatures in the combustion chamber. It will run on lower octane but performance and drivability will suffer.
Try 98 then report back if it still has issues.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby GTTpower » Tue Nov 01, 2011 12:05 pm
Alex B wrote:It's built for 100, run 98.
9.0:1 static compression, on the high end of the scale.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby tiny2009 » Tue Nov 01, 2011 1:07 pm
Slightly unrelated but below is a comparison I did with a VVTi 1JZGTE which is another engine designed for 100. Red line is 95, blue line is 98. I could feel the difference and have the chart to prove it, notice the increase in torque:
and AFR:
tiny2009
Postby Bling » Tue Nov 01, 2011 5:39 pm
MRDOCA wrote:I don't nana it trust me lol. I don't believe having to run 98 is the only way to fix it. It shouldn't need 98. I'll check the sensors And unplug battery and reply after
Running it on 98 is something you should already be doing. Stop being a cheap arse. You abuse a highly strung turbo car on 95 fuel that is probably tuned for 100.
You could always put an aftermarket ECU on it and have it tuned to run on our crap fuel, but I don't see that as being a good fix really.
Postby MRDOCA » Tue Nov 29, 2011 3:40 pm
Ok decided to bump this thread. Now been running 98 for a while now and yes it doesn't do it as bad but still does it. Between 3-4000rpm only in every gear.
Starting to annoy me as I want to turn the boost up and start doing other mods/work to it but obviously can't due to this issue.
MRDOCA
Postby solitaire » Tue Nov 29, 2011 3:45 pm
BZG said his had a broken air intake sensor when his was doing it, have you tried that?
Do these things run map or afm?
AE92, KZJ120, KDJ120
solitaire
Postby dnalunchie » Tue Nov 29, 2011 3:47 pm
MRDOCA wrote:Ok decided to bump this thread. Now been running 98 for a while now and yes it doesn't do it as bad but still does it. Between 3-4000rpm only in every gear.
Every now and then there is a thread where a GTT owner is able to mod their car and have it go fine.
The other 90% of the time GTT's do no like their own standard engine let alone a modded one.
Put simply if you want more power out of your GTT then you MUST be happy risking its complete demise....
If you want a moddable wagon go buy an evo wagon or Stagea 260rs
Current: 90 3sfe Corona
dnalunchie
Postby solitaire » Tue Nov 29, 2011 3:48 pm
I must say, i see a lot of Caldina pinking threads...
its the 3s engine curse!!!!
solitaire
Postby strx7 » Tue Nov 29, 2011 4:36 pm
if you want to modify a GT-T you start of with an aftermarket tuneable ecu, or you factory into the mods bending rods and or melting pistons, rebuilding for forged items and then forking out on top for a tuneable ecu.
Postby MRDOCA » Tue Nov 29, 2011 4:44 pm
I am well aware about what to do to mod cars I've been building and modding familias for years. But all I want to work out is why my car is pinking atm.
MRDOCA
Postby sergei » Tue Nov 29, 2011 4:53 pm
MRDOCA wrote:I am well aware about what to do to mod cars I've been building and modding familias for years. But all I want to work out is why my car is pinking atm.
High boost, high compression, aggressive timing, shitty fuel and a bit of carbon build up.
Postby MRDOCA » Tue Nov 29, 2011 5:08 pm
Say it was carbon build up, what's the "best" product to clean that off without removing the head?
MRDOCA
Postby sergei » Tue Nov 29, 2011 5:17 pm
MRDOCA wrote:Say it was carbon build up, what's the "best" product to clean that off without removing the head?
Subaru Upper Cylinder Cleaner
http://www.trademe.co.nz/motors/car-par ... 565150.htm
Note: not my auction just an example.
Postby MRDOCA » Tue Nov 29, 2011 5:24 pm
Thanks Sergei, I'll give that a try. Worse case scenario I'll have to put it on a diagnostics machine
MRDOCA
Users browsing this forum: No registered users and 29 guests
