EP82 Rear Sway Bar Install
Postby ShiRuBiA » Wed Nov 02, 2011 7:17 pm
Hi guys, this is from Whiteline's website, is it legal to instal it this way, by drilling a hole through the chassis rail?
Andrew
ShiRuBiA
Postby Stu- » Wed Nov 02, 2011 7:20 pm
Not as long as you weld in a crush tube.
I've installed quite a few of these that have gone straight through certs.
Project Thread
Stu-
Postby ShiRuBiA » Wed Nov 02, 2011 7:23 pm
Please forgive my ignorance, how exactly does that work?
Basically drill the hole larger than required and slot a tube through, then the mounting bolts go through the whole lot?
ShiRuBiA
Postby iOnic » Wed Nov 02, 2011 7:25 pm
Postby ShiRuBiA » Wed Nov 02, 2011 7:33 pm
Sweet cheers for that!
ShiRuBiA
Postby tiny2009 » Wed Nov 02, 2011 9:03 pm
Been there done that to an EP91, awesome upgrade. With crush tube it will be sweet, shouldn't need a cert either.
tiny2009
Postby DRFTIN » Thu Nov 03, 2011 9:12 am
do it tidy and no one will notice anyway
do they normally need a rear bar? our old race car used to oversteer a heap even with a bigger front swaybar
DRFTIN
Postby Leon » Thu Nov 03, 2011 9:55 am
Technically to be a nerd about it, yep, if somebody pulls a pissy fit about it, it needs a cert if an inspector deems your drilling holes then fitting the crush tube is strengthening or weakening a structural member of the car.
That said, I had one on my EP82 and nobody noticed (and it was welded re-enforcement plates too).
Yup, they do benefit from the rear bar. Sit a heck of a lot flatter in corners, and the turn in improves a whole bunch.
Postby iOnic » Thu Nov 03, 2011 6:17 pm
Massive difference, this, adjustable panhard rod, strut braces and a good shock/spring combo makes them very go kart like.
Users browsing this forum: No registered users and 33 guests
