Oil Leak Fun Times!
Oil Leak Fun Times!
Postby naqs » Thu Nov 03, 2011 6:46 pm
My Caldina GT-T has been leaking a fair amount of oil lately. Wondering if there are any typical places it'd leak from.
I had a bit of a nosey underneath today, thought it could be coming from the oil filter, as oil is dripping from around that area. but it's also leaking at the back end of the sump too (I think).
Thoughts?
naqs
Postby Dell'Orto » Thu Nov 03, 2011 6:58 pm
Rocker cover
Postby RunningRich » Fri Nov 04, 2011 8:41 am
Numerous places.
The crankshaft main seal is one location I've seen before. It ends up dripping from the sump flange (after running halfway round the engine) and is a bugger to track down.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby strx7 » Fri Nov 04, 2011 8:46 am
RunningRich wrote:Numerous places.
Amen to that, the rear main on my SE104 s/5SGTE became badly pitted and would only leak badly under high cornering forces, the rest of the time it was only enough to make things attract dirt and go gungey. the leak appeared to actually be coming from the inlet manifold even though that is impossible.
Postby Grrrrrrr! » Fri Nov 04, 2011 10:57 am
QFT..
If your 3sgte only leaks from one place you are lucky/not looking hard enough.
Grrrrrrr!
Postby RunningRich » Fri Nov 04, 2011 2:36 pm
Mine doesn't leak!! (now)
I had leak issues after I overhauled the engine. Took me damn near 50000kms to track down. Turned out to be a fine circumferential hairline crack in the o-ring groove of the distributor. The dizzy was off a used import motor and it had a broken dizzy cap when I got it. I suspect it took a hit when piled in the container, just not quite enough to snap it.
On my ST165 the distributor actually snapped off at the same location in-situ. Never explained that one.
Speaking of which the distributor o-ring is another common location. If you have oil inside your distributor it is the lip seal inside the dizzy.
Richard
RunningRich
Postby naqs » Wed Nov 09, 2011 12:49 pm
I think you could be right with the crankshaft seal. Was going through 2L of oil every few days. Need to fix it, so I can drive it again. How hard is it to get to?
More the point, can I be bothered fixing it myself?
naqs
Postby Mr Revhead » Wed Nov 09, 2011 2:34 pm
If you have to ask...
Postby strx7 » Wed Nov 09, 2011 4:21 pm
it is an engine and box out of the car onto the floor job. ideally you need access to a hoist and a free weekend......
Postby Dell'Orto » Wed Nov 09, 2011 4:30 pm
naqs wrote:I think you could be right with the crankshaft seal. Was going through 2L of oil every few days. Need to fix it, so I can drive it again. How hard is it to get to?
Check the oil filter if its going through that much, might be weeping out the seam
Postby allencr » Wed Nov 09, 2011 5:35 pm
naqs wrote:I think you could be right with the crankshaft seal. How hard is it to get to? More the point, can I be bothered fixing it myself?
Difficult enough, much heavier then the front seal stuff but less complicated, and something you should be very sure about as the source/s of the lube, no guessing allowed.
Oil filter tight????
allencr
Postby MAGN1T » Wed Nov 09, 2011 6:02 pm
If it's got too much crankcase pressure, it'll leak. From anywhere it can.
Likewise if the crankcase is in vacuum, it won't leak even with worn seals. That's because the air will leak inwards.
Maybe it's got broken ringlands?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby DeeCee » Wed Nov 09, 2011 7:26 pm
steam clean engine bay and then start monitoring for oil leak area. Will be a lot easier to locate instead of trying to figure out past the grime that is already there.
GT Four Adovansu
DeeCee
Postby naqs » Thu Nov 10, 2011 7:19 am
Mr Revhead wrote:If you have to ask...
Really not in the mood to fix it aye...
strx7 wrote:it is an engine and box out of the car onto the floor job. ideally you need access to a hoist and a free weekend......
I have access to a hoist... free weekend? not so much
Thanks all for the input, Hopefully I'll get it all sorted this weekend
naqs
Postby BZG Wagon » Thu Nov 10, 2011 8:23 am
How hard is it to get a 3sgte out of a Caldina?
BZG Wagon
Postby Mr Revhead » Thu Nov 10, 2011 8:40 am
Usually the easiest way is to use a hoist and drop the whole engine and trans out the bottom
Postby DVSMOTORSPORT » Fri Nov 11, 2011 7:41 pm
If it goes through 2l of oil every few days it must be pretty much dripping out as its idling.
So I would clean the hell out of the engine, make it prisitine, jack it up and have the car leveled out on axle stands, start the engine and watch it with a really good light. Since the car is only idling theres not as much air flowing past etc to blow the oil everywere which means you should be able to see the trail clearly.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
