Fielder z help...
Fielder z help...
Postby doin donuts » Tue Nov 08, 2011 3:13 pm
Hey all,
Wife just got herself a 2000 fielder z(tiptronic),we just went on its first long trip since we got it and I was overtaking a truck and I accelerated-not heavily but enough to make the car drop down a gear,them it's started to feel like it was valve bouncing but wasn't high enough revs and the check engine light came on!!
Stopped,turned car off and on again and light was gone and car drives fine.
Any ideas or anyone here have a diagnostic tool that can do any checks for me? I'm in Auckland
Thanks all
Doug
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby BZG Wagon » Tue Nov 08, 2011 4:50 pm
You might be able to diagnose yourself. If it's anything like a Caldina locate the check connector (usually be close to the drivers door in a compartment around where your knees are). Bridge TC & CG and turn on the ignition. Count the engine flashes then look them up on google work out what the issue is.
Probably easier then having everyone guess - but it sounds like a faulty sensor perhaps.
BZG Wagon
Postby TRDWGN » Tue Nov 08, 2011 5:32 pm
Does it still come on lift? Could have broken the lift bolt
TRDWGN
Postby doin donuts » Tue Nov 08, 2011 5:50 pm
TRDWGN wrote:Does it still come on lift? Could have broken the lift bolt
Yeah it does but not massively?
And cheers BZG, excuse my ignorance but how do I bridge it?
doin donuts
Postby RobertC » Tue Nov 08, 2011 5:53 pm
(connect them) / a get a paper clip bend it in a "U' and put one end in one hole and the other in the other hole.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Users browsing this forum: Google [Bot] and 21 guests
