Steering column Shaft
Postby CelicaGT8 » Fri Nov 11, 2011 6:38 pm
My shaft is too short, i want it about 100mm longer if not more, pics below, its from a st165 Celica, iv converted it to rwd and using a subaru rack.
I havnt measured it if you were wondering. shal do so later.
CelicaGT8
Postby crispy'86 » Sat Nov 12, 2011 10:02 am
Where is it short? Where you marked it with twink on the intermediate shaft? If that's the case surely there'd be something else from a 185 or something that's longer in the intermediate shaft.
Some rwd toyota's are quite long i.e from what i had lying round in the garage ma45? Does the universal fit the subaru rack?
crispy'86
Re: Steering column Shaft
Postby Sideros » Sat Nov 12, 2011 10:51 am
CelicaGT8 wrote:My shaft is too short
Sorry couldn't resisit!
A mate of mine had a similar problem a few years ago, no welder in Palmy would touch it to extend it because of possible issues with fracturing of the join and then of course the huge safety issue that follows.
We got around it by using grub screws, loctite and adding another peice on, although that failed thankfully when he was almost stationary.
I'm not 100% sure what he found to replace it now but others on here may know such as NILPSI or Dell'Orto
If it was me I would find a solid factory alternative instead of trying to extend the one you have.
Sideros
Signwriter
Postby wde_bdy » Sat Nov 12, 2011 11:48 am
Just get a shaft machined up longer to fit into the collapsible section, I think it cost $250 when my mate had the one done for his EH Holden rack conversion. If you want it legal welding a steering shaft is a big no-no, I would talk to your certifier first about any solutions you come up with.
Callum
wde_bdy
Postby crispy'86 » Sun Nov 13, 2011 4:36 pm
I'd almost work out what length you need for the shaft and visit a wreckers to get some dimensions . Some shafts are interchangeable, scary thing is one *shudders* honda universal fitted one of my column shafts so maybe an option too.
crispy'86
Postby CelicaGT8 » Sun Nov 13, 2011 8:38 pm
It needs to be about 100 - 150mm longer, so it will fit out of the firewall, would prefer the half with the bearing to be able to be replaced with a longer one. I hadnt thaught about a supra one, i will look into it. I thaught about going to pikapart and seeing what they had.
Im not exactly sure what i need atm as the rack is not fully mounted, is just easier to nut it out when you have a few pieces you can play with.
The subaru shaft has a different spline
Will look into a supra one and get back to you with what i find.
CelicaGT8
Postby DVSMOTORSPORT » Mon Nov 14, 2011 6:28 pm
If scooby rack has a different spline, why not try a complete scooby column?
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby CelicaGT8 » Mon Nov 14, 2011 6:55 pm
Thaught about that, but then it will cause problems at the other end. Would be nice to keep it looking standard inside aswell.
CelicaGT8
