4age BT blowing black smoke
Postby magweal » Fri Dec 02, 2011 9:28 pm
My black top is blowing black smoke when i put my foot deep on the throttle, I know this is over fueling but is it a quick fix. All that is done is cat removed and a pod n pipe put on.
Also any1 know why I smell burnt oil every now and then, it doesnt matter if I've driven hard or not. The engine was sitting around for about 10 months but I've been running it for the last month thinking it was excess on the mani from the conversion
magweal
Postby BZG Wagon » Sat Dec 03, 2011 12:18 am
If it's black smoke then it's normal and nothing to worry about. The engine runs rich under heavy throttle to stop it from melting into a giant paper-weight.
Those motors are prone to burning a tiny bit of oil too, which is also completely normal.
Burnt oil is most likely leaked or spilt oil somewhere around the exhaust system. Give the engine a good clean and see what happens / look for signs of a leak.
BZG Wagon
Postby Al » Sat Dec 03, 2011 5:08 pm
The lack of cat is the reason you get the black smoke more than likely.
Al
Postby evil_si » Sun Dec 04, 2011 6:52 am
What fuel pump and what fuel reg are you using.
evil_si
Postby magweal » Sun Dec 04, 2011 6:19 pm
Just the standard 1 for the GL although just thinkin it has a aftermarket fuel filter, probably should replace it
98 BZ-T rola SMUGLN V1(RIP)
97 NZ new GL rola now with BZ transfer 80%
magweal
Postby MAGN1T » Sun Dec 04, 2011 10:26 pm
Your oxygen sensor might have died.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Users browsing this forum: Bing [Bot] and 23 guests
