EP71 gearbox same as ee80 and ee90?
Postby Leon » Tue Jan 10, 2012 11:21 am
Picked up a Starlet with potentially busted gearbox
Wondering if the 5sp E motor gearboxes are the same between the Starlet and Corollas
Postby Stu- » Tue Jan 10, 2012 12:10 pm
Pretty much, mounting of the passenger side mount differs - starlet is mounted on the front, corolla on the top. Usually the corolla boxes just need the holes drilled and tapped.
Project Thread
Stu-
Postby rollaholic » Tue Jan 10, 2012 6:02 pm
haha, the voice of someone who has broken alot of starlet gearboxes?
Postby Stu- » Tue Jan 10, 2012 6:11 pm
Dude, lost count years ago. Current setup seems to handle it thank god
Project Thread
Stu-
Postby Leon » Tue Jan 10, 2012 8:08 pm
well if this one is a busted gearbox rather than just busted clutch, I'll be in the market for a cheap gearbox 8)
Postby Stu- » Tue Jan 10, 2012 8:26 pm
Best bet is probably pickapart to be honest, a c150 will do but a starlet c52 is the strongest.
Project Thread
Stu-
Postby Garreth27 » Tue Jan 10, 2012 9:04 pm
seems to be quite a few c52 starlet boxes on trademe at the moment
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby Leon » Tue Jan 10, 2012 9:11 pm
well this is going into a bog stock 2e Starlet likely to simply be immediately sold.
Postby Stu- » Wed Jan 11, 2012 9:43 am
C150 is the cheapest bet then - they are easy to rip down and rebuild if needed
Project Thread
Stu-
Postby Leon » Wed Jan 11, 2012 9:44 am
what are the C150's found in?
Postby Stu- » Wed Jan 11, 2012 9:46 am
They're the stock box for EP70/71.
Basically you can look at almost any c series box, but just take note of the passenger side engine mount as above. Anybox from behind an e series engine can be made to work.
Project Thread
Stu-
Postby Leon » Wed Jan 11, 2012 10:45 am
Thanks for that info :)
Postby Stu- » Wed Jan 11, 2012 10:53 am
No probs - good luck
Project Thread
Stu-
Postby DexGT » Wed Jan 11, 2012 8:20 pm
As an indicator of how the C150's go , that's whats in Jilly's car , seems to be holding up ok :lol:
DexGT
Postby Stu- » Thu Jan 12, 2012 1:35 pm
C150's are fine - just don't do big rpm clutch side steps.
Project Thread
Stu-
