Lightweight flywheel for 3sge Beams celica 1997.
Postby melloman11 » Sat Jan 21, 2012 9:27 pm
Hi all,
I'm after a lightweight flywheel for a 1997 SS3 beams celica.
I've had a good search and this http://www.trademe.co.nz/motors/car-parts-accessories/toyota/clutches/auction-440094362.htm is all I have found, is the lightest flywheel I can purchase for the beams 8.8kgs? or can I go lighter? I'm after something lighter than stock but still in the daily driver range. Cheers.
melloman11
Postby Dell'Orto » Sat Jan 21, 2012 9:51 pm
Thats for an Altezza, pretty sure the Celicas didnt have a dual mass flywheel! (hence the DMR replacement).
JUN will likely do a light flywheel for them, ask Mac @ 41
Postby touge_ae101 » Sat Jan 21, 2012 10:02 pm
they come up on trademe quite often as lots of altezzas etc come in from japan with good flywheels+clutches. and this makes them a bit of a bitch to drive so people take them out and sell them cheap quite often. keep an eye out.
touge_ae101
Postby melloman11 » Sun Jan 22, 2012 12:53 am
Good to know, I havn't bought the celica yet it's getting mechanically inspected. If that checks out its a done deal. Just going over what mods I can do to her :) .
There was an expired auction http://www.trademe.co.nz/motors/car-parts-accessories/toyota/engines/auction-414298055.htm Thats the kind of thing I'm after. I got in touch with the seller and he said he'd long sold it and thought the company that made them had gone out of business :(
melloman11
Postby Bling » Sun Jan 22, 2012 1:16 am
Bazda sells that Fidanza in the sponsors section so I doubt they have gone out of business. The local shop the trademe seller got it from may have gone out of business though.
viewtopic.php?t=84938
Postby Dell'Orto » Sun Jan 22, 2012 9:56 am
Clutch Industries used to import Fidanza, but they stopped due to lack of demand.
Postby RomanV » Sun Jan 22, 2012 4:33 pm
you can NOT use altezza flywheels.
Buuuuut the good news is that you can use any flywheel which fits a gen 2 or 3 3sge.
Cant use a 3SGTE one though, unless you use a different clutch centre to suit the S gearbox.
Postby ®usty » Sun Jan 22, 2012 6:05 pm
Are you sure about those flywheel weights?
From what I've read...
Redtop 3S-GE is 6.4kg
Gen 3 3S-GE is 7.5kg
®usty
