Radiator filter
Radiator filter
Postby gt4dude » Thu Feb 09, 2012 3:51 pm
Anyone know where to get the parts to make something like this?
http://www.jag-lovers.org/xj-s/book/CoolantFilters.html
I been around Mitre 10 and place makers couldn't find anything suitable, that website is a good read. I noticed my new radiator is getting blocked again and my temp is starting to rise, I'm sick of trying to flush my cooling system all the time
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby limbo » Thu Feb 09, 2012 6:22 pm
I was looking at getting one, they are not to expensive see my ealier post, from memory $60 AUD plus postage
Never ended up getting one tho.
http://forums.toyspeed.org.nz/viewtopic.php?t=85049&highlight=
limbo
Postby Mr Ree » Thu Feb 09, 2012 6:30 pm
What is causing you new radiator to get blocked? I would look into curing that before adding the filter.
Is it a reaction between different coolants/water wetter? Electrolysis?
wak thud gush!
Mr Ree
Postby Bling » Thu Feb 09, 2012 6:43 pm
Mr Ree wrote:What is causing you new radiator to get blocked? I would look into curing that before adding the filter.
This^^
I don't see how a filter will help solve much.
Postby gt4dude » Thu Feb 09, 2012 6:56 pm
Just bits of crud from this
that didn't come out with a garden hose along with whatever rust scale it took with it.
(To save the bullsh1t posting, yeah t-stat out, yeah reverse flush yada yada yada)
200AWKW / 370NM
gt4dude
Postby Mr Ree » Thu Feb 09, 2012 7:19 pm
And dont forget to reverse flush the heater core several times too ;)
wak thud gush!
Mr Ree
Postby DVSMOTORSPORT » Thu Feb 09, 2012 8:56 pm
gt4dude wrote:Just bits of crud from this
Well theres your problem right there. Stuff using crap like that.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby allencr » Thu Feb 09, 2012 9:13 pm
Water AND compressed air!!!!
Forward & reverse, no thermostat, engine, radiator & heater core.
Garden hose full on into inlet/outlet, rag/duct tape/whatever wrapped tight to mostly seal it, then put the air 90psi+ into a hole/slit in the hose & blast away.
Go easier on the heater core, it can't take the volume the others can.
Yes, you do get wet, and it isn't going to get out all the mineral buildup, but that filter BS is a joke.
I used a diving tank with over 1500psi to clean out some deteriorated hose crap from a radiator's upper tank. It probably had enough volume to destroy things, use some judgment/discretion on your stuff!
Pictures? FU! :wink:
allencr
Postby iOnic » Thu Feb 09, 2012 9:19 pm
allencr wrote:Garden hose full on into inlet/outlet, rag/duct tape/whatever wrapped tight to mostly seal it, then put the air 90psi+ into a hole/slit in the hose & blast away.
^ Take pics of results plz.
Postby Mr Revhead » Thu Feb 09, 2012 10:16 pm
seconded 8O
Youtube it
Postby Mr Ree » Fri Feb 10, 2012 9:03 am
hmmmm....
wak thud gush!
Mr Ree
Postby RS13 » Fri Feb 10, 2012 12:32 pm
Another quality allencr post!
Don't put 90psi through your cooling system. Most radiator caps release pressure at 15psi, with 6 times that if there was a blockage you'd blow seals and crack plastic.
The cooling system can handle a bit of crap floating around without much issue, those filter things IMO are just a gimmick and would only end up causing a restriction or blockage themselves.
Me personally, I drain coolant, fill with water, run the engine for 10 mins, drain, repeat a couple of times until the water comes out clean, then fill with coolant. Never had a problem. If the radiator is blocked again, flushing with a garden hose won't do much, it really needs the top taken off and lanced properly.
RS13
Postby Mr Revhead » Fri Feb 10, 2012 1:05 pm
I can sell you a proper coolant filter if you want.
But if I were you I'd be looking to overhaul the system properly
Postby Malcolm » Fri Feb 10, 2012 1:07 pm
RS13 wrote:Another quality allencr post!
Sounds like the intention is to use the pressure to blast the water through more forcefully, rather than pressurising the system. I don't think a rag wrapped around a hose is going to hold 90psi.
Postby RS13 » Fri Feb 10, 2012 1:22 pm
Still, would you risk it?
RS13
Postby Malcolm » Fri Feb 10, 2012 2:19 pm
I probably would actually
edit: with the other end of the system open, the risk is pretty damn low of pressurising it, even if you've made an awesome seal on the inlet
Postby RS13 » Fri Feb 10, 2012 2:32 pm
*shrug* each to their own I guess. Just doesn't seem like a good practice. Maybe if you've got half a clue and are very careful, but I can see guys pulling off a radiator hose and feeding 90psi through it without considering the more delicate parts.
RS13
Postby Grrrrrrr! » Fri Feb 10, 2012 3:24 pm
Malcolm wrote:I probably would actually
I agree with malcolm, if one end of the system is open and you somehow manage to build enough pressure to crack/pop a top tank off all you've done is save the radiator shop some time, 'cause that core is going to need cleaning out properly/replacing.
Grrrrrrr!
Postby Mr Revhead » Fri Feb 10, 2012 3:30 pm
Is be more worried about the force than pressure
Postby Quint » Fri Feb 10, 2012 4:02 pm
pressure is force over area :/
Quint
