wiper racks
wiper racks
Postby themaleman » Fri Feb 24, 2012 7:15 pm
hey dose anybody know if all ae92 wiper racks are the same? i went to pickapart and got 1 from an ae something (dont think it was a ae92) but the bolts that hold the mount to the body were backwards
wondering if any ae92 rack will work.
Liam
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Mr Revhead » Fri Feb 24, 2012 7:32 pm
Define wiper rack? In all my years I have never heard that term before. Might help someone answer your question
Postby Grrrrrrr! » Fri Feb 24, 2012 7:40 pm
I think he means the wiper linkages.. and if this search result from toyodiy is right, it looks like anything xE9x is the same
Grrrrrrr!
Postby themaleman » Fri Feb 24, 2012 7:40 pm
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Fri Feb 24, 2012 7:44 pm
the difference between my levin one and the one i got from pickapart is in the mounts that hold the shaft through the body. the shafts are set on an angle through the plate that holds them to the body, when i fitted the pickapart one it shot the shafts out pretty much 180 degrees from the correct angle, as in the 3 holes you see are on the wrong side
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Grrrrrrr! » Fri Feb 24, 2012 7:49 pm
heh, okay, so the coupe one is specific to the coupe. so you need a levin or trueno one.
Grrrrrrr!
Postby themaleman » Fri Feb 24, 2012 7:56 pm
i just had a look at toyodiy (completely forgot about that site!) and ur right the part numbers are the same, will have another look at fitting the one i got tomorow. thanks for ur help
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Fri Feb 24, 2012 7:58 pm
on a side note, dose the position of the motor arm matter? it moved when i took it out
4agte ae92 Levin
a15 powered sj410
themaleman
Postby gmacrae » Wed Mar 28, 2012 8:15 am
motors arm position shouldnt matter a bit, just run it for a couple cycles before you put the wipers back on. It'll move back to its home spot the first time you run it.
gmacrae
Postby themaleman » Wed Mar 28, 2012 4:51 pm
mint cheers!
4agte ae92 Levin
a15 powered sj410
themaleman
