Broke my gearbox a little....
Postby cat007 » Tue Jul 31, 2012 11:25 am
So after doing a 'wee skid' a couple of weekends ago I notice a slight knocking sound. Luckily I'm only a few hundred meters from home so I drive home and park up.
Haven't touched the car since then but then last night I thought I'd put her in the garage and record what the noise sounds like:
http://www.youtube.com/watch?v=7hYI4KLsQgY
Clutch in, makes no noise, clutch out, sounds like a wood pecker lol
Shifts through all gears including reverse fine. Each gear has drive.
Before I pull the box out and take the housings off - lets play "What could it be?"
Postby FST4RD » Tue Jul 31, 2012 1:33 pm
My starion did exact same thing.
Broke 2 teeth off 2nd and also broke the rivets in the clutch. So not sure which was making the noise. I assume it was the clutch as when I pressed the pedal in it stopped making noise.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby cat007 » Tue Jul 31, 2012 1:36 pm
Seems odd how it's such a consistant knocking. I first thought maybe a dropped bearing but then I thought that would result in a more inconsistant knocking/scraping?
Postby Quint » Tue Jul 31, 2012 2:19 pm
Sounds similar to my 1g when i ran the mains :/ does the clutch pedal vibrate like crazy when it's engaged? Drop the sump and check the pan (or cut the oil filter in half), if it's full of metal, brrm bmmmm.
Quint
Postby cat007 » Tue Jul 31, 2012 2:21 pm
Quint wrote:Sounds similar to my 1g when i ran the mains :/ does the clutch pedal vibrate like crazy when it's engaged?
Nope - clutch pedal is smooth as.
Knocking appears to coming from behind the engine - it does sound like engine bearing knock - but it's further back than the engine - thank god.
Postby FST4RD » Tue Jul 31, 2012 2:44 pm
It could be a broken tooth as well. Push the clutch in and everything stops spinning, release it and the broken teeth will be catching and knocking.
Mine was real constant as well, but the faster the motor speed the faster the knock.
FST4RD
Postby 85AW20v » Tue Jul 31, 2012 9:03 pm
Does the frequency of knocking change in different gears? If not, I'd be thinking maybe something in the clutch area rather than the gearbox...
See ya
Simon
85 MR2 20v
85AW20v
Postby iOnic » Tue Jul 31, 2012 9:16 pm
Does your clutch have a sprung center?
Postby cedwards » Tue Jul 31, 2012 10:02 pm
Didn't you rebuild a gearbox a while ago with some mystery washer/bush/ thingy-mabob left over at the end????... If this is the same box i'm putting my money on that being the issue..
viewtopic.php?t=70261&highlight=
cedwards
Postby matt dunn » Tue Jul 31, 2012 10:25 pm
85AW20v wrote:Does the frequency of knocking change in different gears? If not, I'd be thinking maybe something in the clutch area rather than the gearbox...
Noise ina box probably wont change between gears as all the gear are always meshed the same no matter what gear you are in.
Postby cat007 » Tue Jul 31, 2012 10:54 pm
cedwards wrote:Didn't you rebuild a gearbox a while ago with some mystery washer/bush/ thingy-mabob left over at the end????... If this is the same box i'm putting my money on that being the issue..
Yep that's correct! I was never able to find where the C clip went.
You could be onto something! :)
Postby cat007 » Tue Jul 31, 2012 10:56 pm
iOnic wrote:Does your clutch have a sprung center?
Sure does....basic clutch, full face organic clutch plate and 2,800lbs pretty plate. Nothing fancy.
Postby cat007 » Tue Jul 31, 2012 10:57 pm
I haven't noticed. It increases with rpm, don't really want to drive it more to diagnose. Sorry I know that's not particularly helpful.
Postby Lloyd » Tue Jul 31, 2012 11:08 pm
If its making that kind of noise then its going to have to come out regardless. And from the sound of it, it should be really obvious once things are apart.
Pull the box, check the clutch, take the ends off the box and see what isn't pretty any more.
Postby allencr » Wed Aug 01, 2012 12:25 am
Magnet on the plug will tell you something.
allencr
Postby cat007 » Wed Aug 01, 2012 12:39 am
allencr wrote:Magnet on the plug will tell you something.
Yep. If there's chunks then that'll mean something bad lol. Depending on what they look like I should be able to tell where they came from.
However there may be nothing on the magnet which may mean nothing...
Postby rollaholic » Wed Aug 01, 2012 7:51 am
if you care about it, pull it out and tear it down
if you dont, drive it till it stops driving then replace
Postby jacobrjett » Wed Aug 01, 2012 10:06 am
rollaholic wrote:if you dont, drive it till it stops driving then replace
bad bad bad idea
remember cars are a weapon, you dont want to be driving something that could suddenly seize and send you spinning out of control, potentially on the motorway, around school areas etc.
im on the "pull gearbox out now" side
jacobrjett
Postby cat007 » Wed Aug 01, 2012 10:11 am
bad bad bad idea
Yeah I don't plan on driving it any until I've pulled the box and assessed the situation.
Postby jbod » Thu Aug 02, 2012 12:23 am
cat007 wrote:Seems odd how it's such a consistant knocking. I first thought maybe a dropped bearing but then I thought that would result in a more inconsistant knocking/scraping?
If you remove the gearbox and find the clutch assembly is ok, you will quite possibly find the first bearing in you gearbox that supports the pto shaft that is directly sticking out of the gearbox has failed.when the clutch is out it is all engaged spinning this shaft in the gearbox. Most likely the cage has collapsed and the more you use it, the balls will begin to favor one side and group and seize
jbod
