Quint wrote:Sounds similar to my 1g when i ran the mains :/ does the clutch pedal vibrate like crazy when it's engaged?
85AW20v wrote:Does the frequency of knocking change in different gears? If not, I'd be thinking maybe something in the clutch area rather than the gearbox...
cedwards wrote:Didn't you rebuild a gearbox a while ago with some mystery washer/bush/ thingy-mabob left over at the end????... If this is the same box i'm putting my money on that being the issue..
viewtopic.php?t=70261&highlight=
iOnic wrote:Does your clutch have a sprung center?
allencr wrote:Magnet on the plug will tell you something.
rollaholic wrote:if you dont, drive it till it stops driving then replace
jacobrjett wrote:rollaholic wrote:if you dont, drive it till it stops driving then replace
bad bad bad idea
remember cars are a weapon, you dont want to be driving something that could suddenly seize and send you spinning out of control, potentially on the motorway, around school areas etc.
im on the "pull gearbox out now" side
cat007 wrote:Seems odd how it's such a consistant knocking. I first thought maybe a dropped bearing but then I thought that would result in a more inconsistant knocking/scraping?
